Old 8th December 2006, 08:51 PM   (permalink)
Default Christmas lights tester
I'd like to test bulbs for my Christmas tree without detaching them from the line. How big should an electromagnetic field be to generate in the bulb such a current that it would shine?
Sorry, my english is too poor for such a technical question... Can anybody kindly correct the question in such a way any English people can understand it without needing a graduation in foreign-english?...
jumpjack is offline
Old 8th December 2006, 09:20 PM   (permalink)
Your English is fairly good.
However, I think you mean magnetic field not electromagnetic field.
I don't think it is possible since, to induce a current into the wire, you would need a closed circuit.
Normally the globes in Xmas tree lights are in series.
Therefore you would have to short circuit the wires at the power plug. So if you induce a current into the loop to make the globes glow, it would only work if all globes were intact. If any globe was faulty, no globes would glow thus negating the point of the exercise.
Len
ljcox is offline
Old 8th December 2006, 10:09 PM   (permalink)
I did a little home-made test... with the microwave oven!
Good news: it worked!
Bad news: now ALL bulbs are broken
A big, colorful FLASH demonstrated that a variable EM field can light bulbs even in an open circuit. Funny... but quite "smelly"....
Anyway, now we should "only" understand the maximum strength the field must have to light the bulbs without burning out them...
jumpjack is offline
Old 8th December 2006, 10:15 PM   (permalink)
Could this circuite work on a 12V rather than 115V lights strand ?
Is this the same tecnique used by these tools I just found?
http://www.tooltopia.com/index.asp?P...D&ProdID=29202
http://www.hsn.com/cnt/prod/default....*hm0116*667374
http://www.improvementscatalog.com/p...macs=MP6NEXTAG
jumpjack is offline
Old 8th December 2006, 10:19 PM   (permalink)
I found an interesting project:
http://www.uoguelph.ca/~antoon/circ/xmasbulb.html
I wonder if these tools I just found use this circuitry:
http://www.nextag.com/christmas-ligh...er/search-html
jumpjack is offline
Old 8th December 2006, 10:47 PM   (permalink)
I've seen a tester circuit. It used an xor gate and capacitively couples the two input pins to the light's wires. each pin goes to a probe that is hook shaped. You powered the light string and put the two probes over the wires on either side of the suspect bulb. The probes couple with the wire. If the bulb is good the two wires are in phase and thus the output of the xor gate is high. If the bulb is bad, the two sides are out of phase and the output is low. the circuit is powered directly off the mains AC so it's got safety issues.
one disadvantage is that it doesn't work for multiple burnt out bulbs. I think there is a straightforward enhancement to fix that. I think you could also run this off of an AC transformer for isolation.
sorry, I don't have a schematic. the guy sketched it out for me. I've been meaning to reconstruct it. maybe some day.
philba is offline
Old 8th December 2006, 10:55 PM   (permalink)
I found two possible solutions:
Unfortunately second one appears not to be available in Italy. I wonder if schematic in first link is good for 12V powered lines too.
jumpjack is offline
Old 9th December 2006, 12:39 AM   (permalink)
Some mains meters have a non-contact mains voltage detector.
Also if you hold one leg of a nen lamp and touch the other leg on the plastic insulation there might be enough capacitive coupling to make it glow very dimly. I've used this technique before to find breaks in cables.
Screen name: Aloone_Jonez
Hero999 is offline
Old 9th December 2006, 12:58 AM   (permalink)
Our electrical utility is giving away strings of LED Christmas lights when you turn in a string of old incandescent ones. I didn't trade any this year because I ran out of the old ones last year.
All the LED ones they gave away this year are recalled because they are a fire hazzard. They are Chinese ones.
audioguru is online now
Old 9th December 2006, 08:43 AM   (permalink)
I use a voltage detector pen to check which bulb is blown of the string.
This only works for the mains voltage strings.
Turn the string on and follow the lamps till the detector stops beeping. that is where your blown bulb is.
Turn the string off, replace bulb and repeat same again from where you replaced bulb.
This is a very simple and fast method of checking where the fault is.
Audioguru ? Where these LED lights mains or transformer ones.??
RODALCO is offline
Old 9th December 2006, 11:45 AM   (permalink)
It will work for low voltage strings too, providing you're careful.
onnect one end of the string to the phase conductor of the mains in series with an HV 1Mhm: resistor then use you voltage sniffer pen to find the break.
I wouldn't recommend this for LEDs chains though as they can be sensitive to ESD and that very tiny current causes by capacitive coupling might be enough to zap some of the more sensitive LEDs. Red LED chains will probably be alright because they're much tougher than the green, blue and white varities.
Hero999 is offline
Old 9th December 2006, 02:30 PM   (permalink)
The LED Christmas lights plug into the 120VAC mains. There are about 35 LEDs in series and I don't see a current-limiting resistor (they aren't bright), don't see a capacitor and don't see a rectifier. They seem to flicker when you move your head near them. I have so many sets of free ones that I haven't used some.
My electrical utility is giving away LED Christmas lights because my area had a very high peak consumption of electricity just before Christmas in the last few years, about the same as the peak in summer when air conditioners are being used. Incandescent lights waste a lot of power, LEDs use hardly any power.
Old 9th December 2006, 02:36 PM   (permalink)
Perhaps each LED has two chips in reverse parallel and a built in capacitor.
Hero999 is offline
Old 9th December 2006, 03:44 PM   (permalink)
I tried this with a non-contact voltage detector. The problem was that I had to seperate the lamp-series wire by quite a bit (around 1.5") from the return and pass-through wires. This was way too much work for the larger twisted strings with the "add-a-string" plug at the end. Maybe my cheapo detector is too sensitive.
philba is offline
Old 9th December 2006, 05:17 PM   (permalink)
No, it probably won't work for the 12V variety especially if it's DC.
However if you don't want to mess around with high voltages you could build an astable running at a relatively high frequency (100kHz will probably do) from the unused gates and connect its output it to one of the Christmas tree light's power lines, then use the other scope to sniff out the power.
Hero999 is offline
Christmas lights driven by music ronjodu Electronic Projects Design/Ideas/Reviews 5 22nd December 2005 07:51 PM
controller for Power Compact Lights timtalk Electronic Projects Design/Ideas/Reviews 7 28th August 2005 08:28 AM
Substitute for fuse bulb in Christmas net lights? davepusey Electronic Projects Design/Ideas/Reviews 20 9th November 2004 05:13 PM
Battery Christmas Lights trinculo54 Electronic Projects Design/Ideas/Reviews 9 17th August 2004 07:19 AM
Drag racing Lights David M Electronic Projects Design/Ideas/Reviews 3 27th December 2003 02:59 AM
