I have a AM modulator circuit and i want to measure using a spectrum analyzer with internal resistance 50 Ohm. This internal resistance is my problem because it is connected parallel and changes the operation of the modulator. I think that a isolator can be used in order to have the correct measures. Does anyone know the suitable isolator (buffer) circuit taking into account an operation at 1.5 MHz minimum (perhaps the buffer may limit the operation and cut high frequencies) ?
You need a buffer stage with a 50 ohm output, a single transistor or FET should be enough, for your low RF frequency it shouldn't be a problem.
Some scopes have FFTs that will allow the use of high input impedance so this wouldn't be a problem. A simple high speed op amp circuit could make a usable buffer for your spec analyzer.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
How much do you want to load your AM modulator? Just use an appropriate impedance matching transformer. Or figure out how to remove the parallel resistor from the spectrum analyzer, if you can take the analyzer apart it should be a simple resistor shorting out the input leads to load the input line to simulate a dipole antenna or 50ohm coax transmission line.
| analyzer, modulation, spectrum |
| Frequeny shifting using SSB Modulation | extcjoey | Electronic Projects Design/Ideas/Reviews | 17 | 29th July 2006 09:29 AM |
| Anti aliasing??? and modulation | andy257 | General Electronics Chat | 5 | 4th January 2005 06:54 AM |
| Newbie modulation question | zachtheterrible | General Electronics Chat | 14 | 7th May 2004 01:22 PM |
