Old 4th December 2006, 02:32 PM   (permalink)
Default Need PCB layout
Hi all,
Currently i'm working with tda7560 quad amplifier. Can anyone please help me in it. Actually i find it hard to design a pcb for it. Also i can't find any vero board for it.
Also if any one can suggest me the type of veroboard where the I.C. can fit properly and available in kolkata.
Please help me......
syber is offline
Old 4th December 2006, 09:56 PM   (permalink)
Have a look at the datasheet.
http://www.ortodoxism.ro/datasheets/...cs/mXussuv.pdf
Screen name: Aloone_Jonez
Hero999 is offline
Old 4th December 2006, 10:09 PM   (permalink)
How are you designing your PCB? I assume you're using a form of CAD software, and if so...what PCB CAD software are you using?
I use Eagle (www.cadsoft.de) and it allows you to create parts, both a schematic symbol, and a PCB footprint. Makes life a lot easier once you get acustom to creating custom parts. The datasheet, as hero999 pointed out, has the dimensions for the package, which all you need to create a perfect PCB footprint.
As for 'veroboard', I've yet to see a generic' prototyping PCB (veroboard) with 1mm pitch (the pitch of the pins on the 'tda7560'), 1.27mm (0.05") yes, but not 1mm.
For prototyping with that chip, I'm afraid you're going to have to either use CAD software that allows creation of custom parts, or at least manually design the PCB completelyfrom scratch using the dimensions given in the datasheet. As for production....if getting a full PCB manufactured is not possible (beit for financial/geographical reasons) you could try andfind someone with a CNC drilling machine, to route out copper tracks in copper clad. And if you're absolutely desperate, manually route out the tracks yourself. I've done this before and its alot of work, 1mm is pretty much the smallest you can so with a dremel and a milling bit, or a knife.
My two cents,
Blueteeth.
Inconsistency is the key to flexibility!
Blueteeth is offline
Old 5th December 2006, 12:20 AM   (permalink)
The datasheet for the IC is full of numbers up to 80W/channel. It even says how much power with a saturated square-wave output. How many Watts per channel do you expect?
I noticed that with a 14.4V supply and a 4 ohm load it begins clipping at about 17Watts.
audioguru is online now
Clap switch - circuit + layout the_music_man Electronic Projects Design/Ideas/Reviews 2 17th May 2006 04:18 PM
MAGIC layout mit_mohit General Electronics Chat 0 28th February 2006 06:32 AM
DC-DC layout efficiency evandude General Electronics Chat 1 26th April 2005 11:25 AM
software for PCB LAYOUT garg29 General Electronics Chat 2 24th April 2005 07:20 PM
Breadboard layout software gjpollitt General Electronics Chat 3 11th January 2004 09:42 AM
