Old 18th April 2008, 12:56 PM   (permalink)
Originally Posted by Pete61
Guess Not!
A can oscillator has four pins.
Thank you all anyway. I will continue experimenting.
The clock is an anniversary present for wife. I have until Aug 1st to complete it.
I'm sure I will will have it all figured out by then.
Thank you all again and take care.
Did she say you have to use 74 series TTL?
Bill
Smart Kits build Smart People
Old 19th April 2008, 09:16 PM   (permalink)
I checked up on the 74160 which is a complete different IC than the 7490 IC's which are cascaded after each other, and are not synchronously driven.
The 74160 needs a bounceless positive edge clockpulse to advance the counting.
You may need to add a buffer or amplifier stage to drive the 74160 counters.
Get some 7490 IC's, they are cheap and will work.
Regards, Raymond
RODALCO is offline   Reply With Quote
Old 21st April 2008, 11:55 PM   (permalink)
http://users.otenet.gr/~ATHSAM/frequ..._with_7490.htm
Here is a website that show how to connect the 7490 in all of it's divider configs.
cls_tec is offline   Reply With Quote
Old 25th April 2008, 05:23 AM   (permalink)
Can anyone send me the simplest circuit of digital clock by using IC 74LS90-93, 74LS47 and 7 segment display to my email address "fhnaseer@yahoo.com", send it within one hour, I have to submit it to my teacher, it is a project for my semester, hurry up, within one hour,
fhnaseer is offline   Reply With Quote
Old 6th May 2008, 06:44 AM   (permalink)
valid quotes
Senash1985 is offline   Reply With Quote
Old 8th June 2008, 04:59 PM   (permalink)
Lol you fail.
heres a website to symbolize your failure
Fail Dogs
Krumlink is offline   Reply With Quote
Old 8th June 2008, 09:18 PM   (permalink)
Maybe if he didn't spend the semester pulling his wire, he would have had time to draw this simple circuit.
6502Dude is offline   Reply With Quote
Old 8th June 2008, 11:09 PM   (permalink)
Can anyone send me the simplest circuit of digital clock hurry up, within one hour,
Here it is!
Oh, darn. Too late.
Anyway, just make up six sets of the attachment, but only one timer, of course.
I'll leave it up to you to figure out how to make it count to 12:59:59.
All those who believe in psycho kinesis, raise my hand.
AllVol is offline   Reply With Quote
Old 20th June 2008, 10:38 PM   (permalink)
nice schematic iyung w, looks interesting.
I just have some questions with your ckt.
1. What is the voltage input of this ckt?
2. Your 74LS47, 74LS08, 74LS32 and other ICs are not connected to Vdd. Do I have to connect it to Vdd and GND for it to work?
3. Does the 1MHz oscillator needs Vdd also for it to function?
Anyone can answer pls. Thanks
http://www.geocities.com/iyung_w/files/24hrs_clock.pdf
ece_jm is offline   Reply With Quote
Old 12th July 2008, 05:49 AM   (permalink)
For an accurate 60Hz timebase, you can use a 3.579545 MHz crystal with an MM5369, 8-pin IC with discrete components. Eliminate the ten-hour 7490 and 7447 with a 7474 D flip-flop and transistor wired as divide-by-two that is on from 10:00:00 to 12:59:59.
Out of curiosity, how would you set the time on this clock?
shokjok is offline   Reply With Quote
Old 12th July 2008, 01:46 PM   (permalink)
The MM5369 has not been made for many years. It needed a supply of at least 9V for its oscillator to work at the 3.58MHz crystal's frequency and its output current was much too low to drive old fashioned TTL. It was good in an accurate low power Cmos clock.
Old 13th July 2008, 12:24 AM   (permalink)
Default digital clock
Hello everyone am new to here but am looking forward for a good project that am planning. I would like to build a digital clock. I saw a lot of schematics some of the schematics dont really explain it very well for me since am a newbie in this and still learning. I would really apriciate it if someone showed me step by step on how to do it am currently building something in multisim but am stuck. thats why i would like to start over with someone who could explain step by step thank you very much.
adokilla is offline   Reply With Quote
Old 13th July 2008, 12:53 AM   (permalink)
Every year, students ask for the circuit for a digital clock that uses old TTL ICs.
Learn about digital logic then design the circuit yourself. Your teacher expects you to do that, not just copy the circuit from somebody else.
Old 19th August 2008, 04:09 PM   (permalink)
Here's mine. Works like a charm. 7490's with 7447's for the LEDs.
The daughter board is the bridge rectifier. Also, I attached the schematic for the new one I'm working on. Same as the old, but has a better time setting circuit. The one that I build basically just uses switches to redirect the 1Hz time base into either the seconds, minutes, or hours sections.
The new clock is going to use a crystal so I don't have to bother with the 60 Hz line. I found a neat trick to get an easy, accurate 1 Hz time base for $6....
http://www.josepino.com/circuits/ind...d_timebase.jpc
krye is offline   Reply With Quote
Old Today, 04:21 AM   (permalink)
Great ! Job well done krye.
I have been to busy with work to post a schema, and build an other TTL clock for which I have the parts and blue LED 7 segment displays.
Regards, Raymond
Clock Pendulum Synchronisation RODALCO General Electronics Chat 9 4th November 2007 02:23 PM
