Old 17th November 2006, 12:08 PM   (permalink)
Experienced Member
William At MyBlueRoom is on a distinguished road
Question ELK-MM443 what would you change if you could.
The ELK-MM443 is a Programmable controller with 4 relays, 4 inputs, X10 (needs interface), RS485 and iButton.
If you had a chance to design your own PLC type device what would you change?
Internally it uses a PIC16C76-04. Myself I'd use a flash chip, possibly an 18F series.
Would you add a RTC? How about a standard RS232 port as well as a RS485. More relays? More inputs? Optoisolation? ZigBee? Memory? Display? Keypad?
http://www.elkproducts.com/products/elk-mm443.htm
• Four analog or digital inputs
• Four relay outputs (2 relay outputs may be jumper programmed for transistor open collector outputs)
• 16,384 program bytes using SIMPLE programming language
• 4 general purpose Counters, range 0 to 255 counts
• 4 general purpose Timers, range 1/10 second to over 255 hours
• Networked to optional PC and up to 31 ELK-MM443’s through a RS-485 data bus.
• X-10
Power Line Carrier Interface. PL513, PSC04 (Transmit Only), or TW523, PSC05 (Two Way).
• Analog transmission MM443 to MM443 and Preset Dim Commands.
• Dallas iButton™ TouchKey Reader with optional ELK-MA100 or ELK-MA290 interface
• Programs the ELK-MM220 (two inputs, two relay outputs)
• Emulates ELK-MM220 for code development
• Program stored in non-volatile EEProm memory
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline   Reply With Quote
pic to detect voltage change max_imum2000 Micro Controllers 9 10th November 2006 12:49 PM
measuring transconductance(gm) walters General Electronics Chat 24 6th February 2006 08:49 AM
12f629 - int on pin change, and tmr0 not working together... SnM Micro Controllers 7 16th November 2004 07:30 PM
Digital Clock Color Change JaTaN General Electronics Chat 1 25th August 2003 01:31 AM
Why do we use .63 as the times the toatal voltage change... helpmeplz Electronic Projects Design/Ideas/Reviews 7 13th March 2003 11:25 PM
