Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 15th November 2006, 06:38 PM
Experienced Member
William At MyBlueRoom is on a distinguished road
Default Simple 6xAAA NiMH or NiCad charger?
I have 6 AAA nimh / nicad batteries I'd like to trickle charge. Can I simply use a resistor and a 9v battery? If so what is the maximum trickle charge I should use C/20?
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline   Reply With Quote
Old 15th November 2006, 07:37 PM
Experienced Member
Hero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to behold
Yes you can, but discharging a 9V battery into some cells seems pretty pointless. The 9V battery will be flat before the NiCads even reach half charge.
Old 15th November 2006, 08:26 PM
Experienced Member
justDIY is a jewel in the roughjustDIY is a jewel in the rough
just jack the 9v, assuming its a alkaline straight into your nimh pack, maybe a blocking diode to prevent back charging... no resistor required... 9v's have such a low mah rating and high internal resistance, your external resistor would just be redundant.
but like Hero points out, it is pointless, since a 9v doesn't contain enough energy to recharge those larger cells.
figure 9v * 300 mAh = 2.7 w/h ... and the aaa pack might be 7.2v * 650 mAh = 4.68 w/h - not even close!
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 16th November 2006, 03:08 AM
Experienced Member
It's not a 9V battery, it's a 9V wall wart. I've seen simple current limiters using a LM317 but I was hoping to simply use a small resistor. Not too worried about the NiCads as they are only 50c each at the dollar store. Using 6 of them to power my ICD2 clone & trainer. 300mah @ 1.25v
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
Old 16th November 2006, 06:02 AM
januar1983 is on a distinguished road
i suggested to use max 712 from maxim semiconductor you can get the free sample of it www.maxim-ic.com
januar1983 is offline   Reply With Quote
Old 16th November 2006, 11:55 AM
Experienced Member
k7elp60 is a jewel in the roughk7elp60 is a jewel in the rough
There is one variable that may cause problems. The typical 9V wall wart is unregulated so the the voltage output may be quite a bit higher than 9V with a small load.
I have had excellent results of charging Ni-Cad and Ni-Mh batteries with a charge current of 0.095C or less. In your case 300 x .095 = 28.5 Ma.
If you figure the wall wart may be at 12V and the batteries are near 1V when discharged you could use a 240 ohm resistor. (12-6)/.025 = 240
k7elp60 is offline   Reply With Quote
Old 17th November 2006, 02:33 AM
Experienced Member
220 sounds right to me.
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
Old 17th November 2006, 04:57 AM
Experienced Member
kchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of light
Nicads are pretty tolerant of overcharge but NIMH are not. You will get better life out of your NIMHs if you charge them at a rate of apx 0.5-1C and terminate on the negative slope of cell voltage change. You can also terminate on cell temperature rise. NIMHs do not take a slow charge very well (Nicads are OK at 0.1C) and their lifespan will be shorter as a result.
kchriste is offline   Reply With Quote
Search this Thread:
Advanced Search
Most complex NiMH / NiCAD charger ever! William At MyBlueRoom General Electronics Chat 1 6th July 2006 03:10 AM
NiCad Charing - with NiMh charger... pittuck General Electronics Chat 2 25th March 2005 11:51 AM
To design and build a 6V NiMH 9000mAh battery charger kiwibikey Electronic Projects Design/Ideas/Reviews 1 28th March 2004 05:58 PM
NiMh Fast Charger for 24V 36V 48V packs, 9Ah design - help! nocman43202@yahoo.com Electronic Projects Design/Ideas/Reviews 0 27th July 2003 09:00 PM
Very simple NiMH Charger.. Klabbis General Electronics Chat 2 3rd July 2003 09:28 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
