Old 1st August 2003, 01:33 PM   #1
Default Schematic for a Ti-83 Calc PC Link
Anyone got one, can be USB, Serial, or Parallel, I got free ones for all of them, all the ones I found online were made by people who don't know how to make schematics. Very poor quality.
E=MC^18357891237358179238, it\'ll still come out right every time. Try it some time, it\'s all relative to the equation.
Take that Einstein.
Nostrafus is offline
Old 3rd August 2003, 07:56 AM   #2
Try this place: http://home.wanadoo.nl/ti83world/cables_make.html Any good?
When life gives you lemons... make a battery.
Electric Rain is offline
Old 5th August 2003, 11:27 AM   #3
I have found a lot of useful stuff on this website www.ticalc.org under hardware, hope it helps.
If nobody is perfect,
then I\'m nobody.
watty is offline
Old 9th August 2003, 02:15 AM   #4
I've decided to build the circuit in the first link...schematic http://home.wanadoo.nl/ti83world/ima...e/bp_print.gif
My Question: Radio Shack only had a 5.1V Zener Diode. WOuld it be possible to swap out the 4.7V Zener the schematic calls for and use the 5.1V instead? I wouldn't think less than half a volt would make much difference, but thought I should ask first.
~Mike
MrMikey83 is offline
Old 9th August 2003, 04:21 PM   #5
Anyone??
Would that extra .4 Volts be too much for the calculator? I started everything last night and all I need is this answer and i will have it done.
Thanks,
~Mike
Old 9th August 2003, 06:58 PM   #6
Shouldn't be a problem, I think there might actually be a way to drop the .4 volts, perhaps try using a slightly smaller power supply on your calc, like 4 AA lith ions (the 1.2v kind so instead of having 6v, you'll have 4.8v) that way, when you get the extra voltage going to it, it shouldn't hurt it.
Take that Einstein.
Old 9th August 2003, 08:17 PM   #7
OK, I wired it and fit it to a case, should work, just need to grab the right size cable at RS before work.
I'll post again if it works.
~Mike
Old 10th August 2003, 03:48 PM   #8
I remember making a cable for my calc about 2 years ago. The bastard wouldn't work until I lopped the lines down to about 4 inches long.
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
