Old 7th November 2006, 11:53 PM   (permalink)
Default Bio-med game interface.
Hey guys how's it going this is my first post so take it easy on me . I'm in my last year of electrical engineering technology and we need to design and construct a final project. On the list of possible topics was the idea of a bio-med game interface. It would be biomed probes detecting muscle activity to control a video game. This idea was badass, so of course I wanna get all over it. Rather than getting an open source game, rewriting the code, building a cable to connect it to the computer, and etc I found an old think geek DIY pong game.
http://www.thinkgeek.com/geektoys/science/8546/
(avaible via partsexpress.com)
So I want to replace the buttons with connector probes attached to circuitry. I figured I'd use a transitor so that when you flex your arm it would produce enough voltage to the base to act as a switch closing the switch on the board. I'm great with the amplificiation of volages, transitors, and such. However if anyone can any point me to where I would purchase biomed probes and any documentation you might know of it would be much appreciated. Also when I finish I'll post it up to the site with video of badass 1 on 1 pong.
teckjunkie is offline
Old 8th November 2006, 01:15 AM   (permalink)
I just put my multimeter on my arm's muscle and flexed it. The voltage was nearly nothing, much less than the 0.6V needed by the base of a transistor.
You will need a high gain opamp circuit to boost the muscle's voltage to a useable level. The high gain will pickup mains hum which will saturate the opamp unless its inputs are balanced and shielded.
audioguru is online now
Old 8th November 2006, 01:18 AM   (permalink)
Oh definately I know that. It would only be milivolts, however I would setup an amplifier circuit (probably 741 op-amp) to amplify it as much as I could without background noise before it goes to the transistor.
Old 8th November 2006, 01:18 PM   (permalink)
Don't use a very old and very noisy 741 opamp. Use a much better instrumentational amp IC or better ordinary opamp.
Old 8th November 2006, 09:32 PM   (permalink)
A little off subject, but have you seen this pong game?
http://www.cyberniklas.de/pongmechanik/indexen.html
Mechanical pong, inplimented with relays and analog sound. real retro, 1940s style. Check out the video of it working!
BART is offline
Old 29th June 2007, 12:14 AM   (permalink)
Default I know its been a while
Just as a followup I did construct this project and got it working great. If you are interested in seeing how it turned out check out http://teckjunkie.com/wiki/
Old 29th June 2007, 02:37 PM   (permalink)
Get some of the connectors used for electrocardiogram (EKG or ECG) recording. They are approved for humans, cause minimal skin reactions, and provide good electrical contact that is relatively insensitive to noise from mechanical movements per se. John
jpanhalt is offline
how can i connect a game buzzer to a computer??? eleanor General Electronics Chat 4 18th October 2006 08:38 PM
pc I/O interface card raus Electronic Projects Design/Ideas/Reviews 4 30th May 2006 10:53 PM
how to interface a mechanical part with C# parthi2929 Robotics Chat 3 15th April 2006 12:11 AM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
USB to IDE interface mixos General Electronics Chat 0 10th December 2003 07:37 PM
