| hi, i have designed a circuit on chrocodile technology and everything works apart from when i press one of the 'set' switches, the MOSFET blows up and it says something about the drain voltage any ideas? same thing happens when using a transistor here is what i have done: http://i14.photobucket.com/albums/a3.../untitled5.jpg it is the MOSFET on the end of the 1st part of the circuit (under the relay coil) that blows up | |
| 6v should be fine, so i'm assuming its the lack of a protection diode on the relay coil? When the relay turns off, the inductance of the coil creates a brief high voltage spike which can damage both transistors and MOSFET's. Look here to see an example of how to use the protection diode: http://www.winpicprog.co.uk/pic_tutorial_extras.htm Its rather an unusual symbol for a MOSFET too? Not the one i'm familiar with.
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| of course.. that did the trick Thanks alot http://www.physorg.com/newman/gfx/news/mosfet.jpg is that something like the symbol you are used to? | |
| yeh... Thanks for your help anyway. all i need now is: Front door opend--->6 second time delay---> if code not entered alarm goes off, if it is entered, alarm is de activated put them both together, and then my alarm is complete | |
| Relay Control Via Transistor Problem | iso9001 | General Electronics Chat | 9 | 31st August 2004 01:26 PM |
| MOSFET Relay problem | guilio_2000 | General Electronics Chat | 16 | 10th August 2004 05:33 PM |
| MOSFET Relay | guilio_2000 | General Electronics Chat | 12 | 21st July 2004 12:49 AM |
| help needed!! Using mosfet to act as a relay | cubert_y | Electronic Projects Design/Ideas/Reviews | 8 | 7th December 2003 07:31 AM |
| Switching relay with a pic? | Jerran | Micro Controllers | 11 | 7th November 2003 05:05 AM |
