hello everyone, can anyone show me how to biuld a long range IR transmitter circuit (can be detected more than 20 centimetres from a IR detector). and any suggestion on the IR transmitter led? please help, i am stucked in he middle of my project | |
We really need a lot more information. Can you post a diagram of what you've done so far? How much more than 20 cm? A TV remote is good for 15-20 feet. The IR laser diode from your slow-ass 4X CD burner might get you half a mile (and possiably do some permanent eye damage...). Most IR LEDs put out plenty of light, just that it's not reflected well. Instead of potential eye damage, it would be better to work on the detection/reciever side. | |
If you are transmitting data, not voice or music, then why not use the simple IR transmitter circuit in a TV remote and a TSOP IR receiver IC? They have a range of about 10m.
| | #4 | |
| | #5 | |
this is the IR transmitter and receiver that i constructed: Quote:
| | #6 |
You don't have a current-limiting resistor in series with your IR LED. It will burn. The TSOP1738 is a complete IR receiver. It needs only a 5V power supply. Get its datasheet from www.datasheetarchive.com . Nigel also has them in his PIC tutorials.
| | #7 |
i have a question, based on the circuit that i constructed, is it possible to boost it so that the transmitting range becomes further?
| | #8 | |
| | #9 |
are you saying that the problem that caused my IR circuit could not work in long range is because of my receiver circuit? so u suggest i replace the normal IR detector with TSOP into the circuit or only plug the IR to the PIC? sorry to bother as i am a noob in electronic stuff. ![]() edited: is the TSOP compatible with other ordinary 2 pin IR transmitter ? Last edited by compass1982; 3rd November 2006 at 06:24 AM. | |
| | #10 |
Yes, your receiver didn't have any gain. A TSOP receiver has lots of gain and many other features. The TSOP is tuned to an IR carrier frequency. The TSOP1736 is tuned to 36kHz, the TSOP1738 is tuned to 38kHz and there are also other carrier frequencies available. Just tune the frequency of your 555 oscillator in your transmitter to the same matching frequency.
| | #11 |
thanks for the reply. TSOP 1738 is being tuned to 38kHz, meaning i must tune my 555 timer exactly 38kHz or is there any tolerance? can u show me the formula to tuned the 555 timer, as i wanted to compare with my formula. thank you
| | #12 |
The datasheet for the TSOP IR receiver shows the width and tolerance of its bandpass, and the datasheet for the 555 shows the formula for its frequency. I think the resistor values in your 555 oscillator are too low, and the capacitor's value is too high. You should add a current-limiting resistor in series with the IR LED so that its current does not exceed the max spec'd on its datasheet.
| | #13 |
i have reconstructed the circuit, is the value of the resistors and the capacitor ok for this circuit?
| | #14 |
your LED doesn't have a current limiting resistor. (hmm, seems like I've heard that before...). it's hard to say which will burn out first - the 555 or the LED. also, you left rst floating, no cap between con and gnd and no decoupling caps. other than that, it's fine. look here for more info: http://www.doctronics.co.uk/555.htm#astable | |
| | #15 |
regarding the TSOP1738, is it the receiver itself already capable to boost the range of 20 metres? or it need additional circuit to make this happen? can anyone show me the programming for this sensor? i am using PIC 16F877A? is the output of TSOP1738 measured by resistance or voltage?
| long, range, transmiter |
| Z8 Encore Error index out of range | mootaccount | Micro Controllers | 2 | 17th October 2006 03:23 PM |
| Long range FM transmitter | sudhan shrestha | General Electronics Chat | 5 | 5th August 2005 12:58 PM |
| long range transmitting question | bootstrap's_bootstraps | General Electronics Chat | 5 | 2nd October 2004 01:00 AM |
| Long range RF remot control circuit | imran1 | Electronic Projects Design/Ideas/Reviews | 4 | 14th August 2004 03:07 AM |
| Massive ERRORS in program. URGENT HELP NEEDED. | davepusey | Micro Controllers | 8 | 18th May 2004 05:13 AM |
