+ Reply to Thread
Page 4 of 5
First 1 2 3 4 5 Last
Results 46 to 60 of 67
Thread: need of long range IR transmiter
  1. #46
    panadol Newbie
    Join Date
    Nov 2006
    Posts
    20
    ok, btw, to im not good in PIC, hence i am using 2 555 to limit the pulses....
    does anyone know of any IR module that are active high and receives continuous pulse?
    the only one i found is SFH 5510-38.but its not available in my place/area.
  2. #47
    captnstoed Newbie
    Join Date
    Nov 2006
    Posts
    20
    I am looking to build this circuit for similar reasons. I need to know how to pulse the ir without the use of the pic, or is that the only way? I need only to send a beam of ir energy (10-20 feet) that, when broken, pulses a signal relay.
    Also, could a laser be pulsed at a freq. that a reciever would "see" and reduce interference?
  3. #48
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    We were talking about using a TSOPxxx IR receiver IC and an IR transmitter made with two oscillators. One oscillator is at 38kHz and the other oscillator causes the 38kHz to be in bursts. Two 555 oscillators can do it easily.
    Most TV remotes use this method and the range is at least 10m.
    You are talking about using a laser which is not IR and which probably won't be received very well by an IR receiver IC.
  4. #49
    HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    Quote Originally Posted by audioguru
    Oddly enough, I did a similar experiment earlier today. I made an IR proximity alarm (first microcontroller project). I get about foot range, but it triggers every time I use a remote control. So, I wired up a laser pointer on the breadboard I used to develope the project, in place of the IR emitter. It triggered the PCB version. Took everything outside, set the alarm on the back fence, triggered it from my porch about 60 feet away.
    Point of the experiment was to see if the IR module would work from a laser pointer, laser trip-wire project I've been thinking about. Need to wire something up and see if the module can handle continous 38kHz pulses, as I have had no luck turning it on and off in my program (want to reduce battery consumption...).
  5. #50
    captnstoed Newbie
    Join Date
    Nov 2006
    Posts
    20
    I see ..... what freq. should the second oscillator be tuned to? I am getting my order together.
    Harvey, what type of reciever was it that you used? Was it an IR or ?
    Did you try it in the sun or shade?
  6. #51
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by captnstoed
    The datasheet says 1400Hz max, but if your square-wave isn't square then use a lower frequency maybe 500Hz. This second oscillator should gate the 38kHz by connecting its output to a voltage divider at the reset pin of the 38kHz oscillator.
  7. #52
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    Its an IR module, and the sun was just starting to rise, so mostly dark. Can't see a laser pointer very far in daylight.
  8. #53
    captnstoed Newbie
    Join Date
    Nov 2006
    Posts
    20
    I have a laser that you get at one of those "chain stores that sell everything" and I can see it well in the day light. The neighbors house is easily 60-75 feet away and I can see is against their outside wall. You do need some kind of large flat surface to locate it and aiming is tough at that distance.
    What about modulating both the laser and the IR led? The laser would be useful to aim with.
    Im going to try that with mine. Im waiting on parts now anyway!
  9. #54
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    You can pulse the laser at 38 kHz and it will trigger the IR-Reciever-Module directly. The laser isn't as bright at 38 kHz, it's only on half the time. I did run the output from the MCU through a transistor to see if higher current would help, but its been kind wet and rainy lately. Does seem slightly brighter, but not as much as I hoped.
  10. #55
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    The case of a TSOP1738 IR receiver IC is black and blocks visible light very well. I know a red laser is very bright but look at this graph and try to determine how little of the red light will be detected.
  11. #56
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    Don't have a part number on the reciever module, but it works. Having a rainy chrismas, figured I'd mess with it a little further. Wanted to bounce the laser off a mirror, total pain in the ass to line up that way. Have to figure out something. Had some camera mounts with ball swivels, but no idea where I put them...
  12. #57
    mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent
    Join Date
    Oct 2006
    Location
    Hyderabad, India.
    Posts
    2,476
    Blog Entries
    1
    Hi HarvyH42,
    To incerase the range, i understand that we have to tune the IR TX (555 frequency to be close ly equal to to IR Rx and only then the range will increase,
    Reg arranging mirrors, i feel it may be possible by first looking with a red Laser torch (used as pointer in presentations.) you may perhaps initially arrange mirrors by using stick gum from your hall to another room and to a third room from there.
    After being able to align with red laser troch and the final point can be substtuted with TSOP Rx and the torch by IR Tx perhaps, sir
    Also, you may be able to park your car away and use its View finder mirror to reflect the signal back. of course you have to temporarily substitute by sticker , a flat mirror across it and orient it to reflect you signal back to a wanted point. however a visible red laser light is purposeful, sir
    regards
    Regards,
    Sarma.
  13. #58
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    It was just quick experiment to see whar kind of distance. Didn't really think lining up a tiny dot on a small target would be such a pain. Need to make something that will do very fine adjustments and not move around. Got a few ideas with a ball joint, couple of screws and springs. Just no spare time to build lately. Hopefully after the holidays.
  14. #59
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by HarveyH42
    A little advise - think BIG, think STRONG, think HEAVY - it mustn't move at all!, and the greater the distance the more solid it must be.
  15. #60
    captnstoed Newbie
    Join Date
    Nov 2006
    Posts
    20
    Ive got the tsop32238 pn the bread board. Can I plug it into a comparator to get it to energize a small signal relay or will it have to go through a pic? I tried a transistor with no luck.
+ Reply to Thread
Page 4 of 5
  1. Long range FM transmitter
    By sudhan shrestha in forum General Electronics Chat
    Latest: 9th February 2010, 12:32 PM
  2. Z8 Encore Error index out of range
    By mootaccount in forum Micro Controllers
    Latest: 17th October 2006, 02:23 PM
  3. long range transmitting question
    By bootstrap's_bootstraps in forum General Electronics Chat
    Latest: 2nd October 2004, 12:00 AM
  4. Long range RF remot control circuit
    By imran1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th August 2004, 02:07 AM
  5. Massive ERRORS in program. URGENT HELP NEEDED.
    By davepusey in forum Micro Controllers
    Latest: 18th May 2004, 04:13 AM
Tags for this Thread
