Old 7th October 2007, 08:03 PM   (permalink)
Originally Posted by oliverb
Yes the cct board can be removed or left in it's up to you.
The diagram for the 4093 is at the top of the page just arrange your light sensors to o/p a 2sec pulse.
You say to o/p a 2 sec pulse, sorry I'm a little confused here .Are you saying triggered for a 2 sec period or 1 pulse every 2 secs?
The 4093 will everse the polarity to the drive coil twice for every 2 sec pulse giving your 1 sec drive.
AHHH! Did not realise that I would use the same circuit
Mark
wombweller is offline
Old 8th October 2007, 03:17 PM   (permalink)
use Opto isolator to supply 50Hz pulses at say 5V and after due division it can run as a bus at TTL level. whereever you need put a resistor and Red LED in series and return to ground.
the drop acroos the LED should be suitable to your needs to drive 4093,
Regards,
Sarma.
mvs sarma is offline
Old 21st October 2007, 09:52 AM   (permalink)
I am building a new slave clock for my master clock (see under projects mater clock woth 7 segment dislay).
I have an old 12" dial clock case and plan to use a 30 sec clock motor for the hours and mins and 2 modified quartz clock motors for the seconds and date displays. I have enclosed a mock up picture of how the clock should look.
I have built a driver for the quartz clock motors using a 2 sec pulse from my master and a 4093 chip I had spare.
The cct works fine and has driven the quartz clock motor perfectly over the last couple of days.
I am not sure how to protect the 4093 chip from back emf from the motor coils. I would normally use reverse diodes across the motors but as the cct reverses polarity to the motors every second I don't think ths will work.
Any ideas?
Thanks.
Brett.
Brett
How did you get the callender from the quartz movement to run as it should?
Regards Mark
Old 27th November 2007, 01:30 AM   (permalink)
Default Gents GPO 36
oliverb
Hi, I bought a Gents GPO 36 master clock of our local auction side, Trade me a couple of weeks ago.
It is in very good condition and provides 1, 6 and 30 seconds impulses.
The timekeeping is very accurate and the noise is not bad at all.
The drive to the pendulum is via Hipp Toggle.
Mine has a 30 seconds slave dial built in as well.
I will also do some projects to get the one second impulses counted via an electronic counter and perhaps via an opto coupler.
I will keep this thread alive with results,
Kind regards, Raymond
RODALCO is offline
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
mechanical quartz clock schematic bdcroucher General Electronics Chat 5 21st October 2006 10:15 PM
Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) smilen Micro Controllers 15 21st November 2005 10:23 AM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
Quartz Analogue Clock from 80's model car Zarniwoop Electronic Projects Design/Ideas/Reviews 2 10th November 2003 02:27 AM
