Essentially the electret mike has a permanent charge stored on the active element, this removes the requirement for an external supply - but adds the requirement for a buffer, which then needs a supply itself. Check Wikipedia! http://en.wikipedia.org/wiki/Electret | ||
| My my my. This is gonna be a fun place...lol. What is piezo-electric material? Does it require electricity to produce electricity? You go to Wikipedia for electronic advice?....LOL That's too much...LOL. That one takes the cake!!!! A condensor mike requires no power! Period! The teacher has spoken. | |
| Sorry, what has 'piezo-electric' got to do with condensor mikes?, piezo mikes are a completely different beast, and you are quite right that piezo mikes don't require any power. Quote:
And even teach absolute rubbish! | ||
| Because condensor mikes have piezo-electric crystals in them. | |
| | (permalink) | |||
A condensor mic needs a 48V power supply to allow the capacitive voltage divider action of the diaphragm. An electret mic has the 48V built-in on its electret material. An electret mic doesn't have an amplifier, it has a FET transistor impedance converter which doesn't have much voltage gain. Quote:
There are many FM transmitter circuits on the web. Most use just the transistor's small changing capacitance to produce the FM. Some use ordinary diodes or transistor junctions as varactors.
__________________ Uncle $crooge | ||||
| Whatever. I'm not gonna go on and on about a condensor mike. Quote:
| | (permalink) | ||
| Another reason I don't like that design is: Notice I said it will vary with frequency and amplitude. That means the amplitude of the audio signal will effect the collector current thereby producing AM components as well. In this case you will need a limiter circuit to get rid of the AM. Now you run the risk of audio distortion. I would much rather modulate the tuning section of the oscillator. Then you won't have any unwanted AM components. Edit after I saw your design: I assume your pre-emphasis is C9. I don't have a problen with that but where is the buffer amp you speak of? A buffer consists of an emitter follower or darlington pair amplifier and yes you are right, buffers a very good idea! I use buffers all over the place. Especialy following the all important oscillator. Last edited by mr.gone; 13th November 2006 at 06:10 PM. | |
The IF amplifiers of all FM radios have a limiter that rejects AM. I can't hear distortion from my FM transmitter on my very high quality stereo tuner nor on my cheap clock radio. If I wanted to be an FM broadcast station operator then I would have made this frequency-synthesized MICROMITTER one with a PLL and varactor diode. It is stereo and also has pre-emphasis.
C4 provides pre-emphasis (boosts the high audio frequencies). C4 has a different value for the different amounts of pre-emphasis around the world. Transistor Q3 buffers the oscillator so that things near the antenna don't change the oscillator's frequency. It also amplifies the RF power.
| OK buddy! I don't want to get off on the wrong foot here. It's just that I got attacked about the condensor mike and I have done too many designs with them, but like I said, I'm not gonna go there with you. Now there is something to be said for cheap and dirty. I have designed PLL FM transmitter using PIC16F84 and Motorola MC145149's. I also have designed stereo multiplexers with discrete components because at the time a common chip (the RHOLM BA1404) was not redily availble. You simply run your left and right adio into the MUX and you get a composit signal that will modulate the tranmitter oscillator or in my case the VCO with a stereo signal. I would post the cotton picker but I did it so long ago it is only in Orcad SDT which runs in DOS. The only IC is a divider used to obtain the 19KHz pilot and carrier for the 38KHz double sideband signal. Last edited by mr.gone; 13th November 2006 at 07:00 PM. | |
| Here's one of my FM broadcaster designs: Crap! can't figure out how to add an attachment. Last edited by mr.gone; 13th November 2006 at 07:20 PM. | |
What are the functions of transistors Q7 to Q159?
| What are you talking about? I didn't even attach anything. It won't let me. | |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| 2-channel 315 MHz Key-Fob transmitter | adamthole | Datasheet/Parts Requests | 1 | 9th June 2005 10:31 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| 2.4 transmitter circuit help | abe | Electronic Projects Design/Ideas/Reviews | 1 | 19th July 2003 10:50 PM |
