| If you don't have a drill bit of the correct size or a special stripboard tool then don't worry. The best way is to gently make two cuts next to each other then remove the bit inbetween with a soldering iron. Sometimes it's best to solder a piece of copper tinned wire to it, leave it to cool then pull it off, it should remove the track. If you want to save space and money then use the LM78L05 in a T092 package, but as audioguru says it's only a goods idea if you're planning to use a 9V power supply, in which case it's also a good idea to add a 100µF capacitor across the power rails.
| | (permalink) | ||||
__________________ Superman returns.. | |||||
| My drill bit has a diameter a little more than the width of a copper track on the Veroboard. Here is a pic showing track cuts and a red screw-hole:
| Buy a proper track cutting tool, they cost very little, and it's SO much easier than using a drill bit - I used a drill bit for years, then I got round to buying the proper tool, I couldn't believe the difference!. | |
| I don't know where to buy real Veroboard anymore. I think Vero doesn't make it and the employees set up their own company but its website doesn't say much.
| Dosen't really matter if it's real veroboard or not?, the spot face cutter still cuts it - and they are easily available. Here's one place http://www.maplin.co.uk/search.aspx?...1m11&worldid=3 | |
| Maplin's spot face cutter looks like the last real Veroboard one I had, same type and colour. My first one had a wood handle, not plastic. I don't have the tools anymore and there aren't any Maplin shops anywhere around here. My drill-press can cut two spots per second.
Maplin was only an example, almost any electronics shop stocks them - certainly RS Components do, and they are worldwide. | ||
| I agree. I used to use a drill bit, but before a project that I knew would need many breaks, I bought the proper handled tool. It is very much better yeah. Mine was from Rapid
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| | (permalink) | ||||
| The 100uF supply bypass capacitor is good with a battery, but it might not be enough to stop hum from your power supply. Most low dropout regulators must have a pretty big output capacitor or they oscillate. The one I used needs 100uF. A 7805 or 78L05 is fine with a smaller output capacitor, a 0.1uF ceramic disc is recommended on its datasheet. I mark where the tracks need cutting with a marker then cut them before mounting and soldering the parts.
| | (permalink) | |||
The difference between 78L05 and 78LS05 is only the size right? Thanks
| | (permalink) | ||||
EDIT: It's output impedance is a bit higher so it's regulation isn't as good as the LM7805 but for small circuits it's more compact and cost effective.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 12th November 2006 at 02:17 AM. | |||||
| Oh! I mixed up the 7805 with the low drop out voltage regulator... For a low drop out voltage regulator, a 100uF is needed if battery is used; bigger capacitor is needed if power supply is used, right? For a 7805, just stick on ceramic capacitor, for both the battery and power supply? Thanks
| | (permalink) | ||
150k for R2 and 28k for R3? This is very close to your original design. Quote:
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| 2-channel 315 MHz Key-Fob transmitter | adamthole | Datasheet/Parts Requests | 1 | 9th June 2005 10:31 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| 2.4 transmitter circuit help | abe | Electronic Projects Design/Ideas/Reviews | 1 | 19th July 2003 10:50 PM |
