| Okay, thanks! My field strength meter shows only 40mV maximum, when the meter antenna is very near to the transmitter antenna. Both of the antenna are around 70cm long. But you told me that yours can up to a few hundred mV isn't it? Thanks
__________________ Superman returns.. | |
| My signal strength was measured nearly 2 years ago. I think it was almost 10 times more than yours.
| Wow. But I don't think there is any problem with my transmitter, maybe the meter?
| Didn't you add an emitter resistor to the output transistor to reduce its power?
| Oh ya, I did. So this can reduce the transmission distance isn't it? I thought it is only reducing the power dissipated by the transistor.
| The emitter resistor reduces the voltage and the current for the output transistor. Power is voltage times current so the power output and heat are both reduced a lot.
| Yes, I got it. Thanks
| i want to know the range of this mod4 transmitter | |
| please iwant design a fm transmitter with range above 5km please help me Last edited by MALLI; 28th July 2008 at 06:41 PM. | |
| My Mod4 FM transmitter has a range of "across the street" to a cheap FM radio. Its range is about 200m to my cheap Sony Walkman FM radio with its antenna attenuator set to "distant". Its range is about 2km to my very sensitive home stereo and my very sensitive car radio with nothing in between. 10km range will need a very sensitive radio and enough output power to cause interference and is probably against the law without a licence. If you make it yourself then you won't be able to licence it.
__________________ Uncle $crooge Last edited by audioguru; 23rd July 2008 at 09:45 PM. | |
| Don't forget that it's a squaare law so to double the distance you need quadruple the power. You could try a high gain aerial on both the transmitter and receiver which will boost the range in one direction only.
| i want to build this fm transmitter please help me how long it can transmit | |
| what is maximum distance that no need to take licience | |
| please send working & circuit diagram of this fm transmitter | |
| Use the EDIT button, it looks like this: ![]() The distance this transmitter can cover depends on how sensitive the receiver is and if there any objects obscuring the path. We don't know what the laws are in your country because you haven't filled your location in. Look at the start of the thread for schematic of this transmitter.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 28th July 2008 at 07:19 PM. | |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| 2-channel 315 MHz Key-Fob transmitter | adamthole | Datasheet/Parts Requests | 1 | 9th June 2005 10:31 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| 2.4 transmitter circuit help | abe | Electronic Projects Design/Ideas/Reviews | 1 | 19th July 2003 10:50 PM |
