Old 25th October 2006, 10:28 AM   (permalink)
Default Watering Systom Circuit
Thank you for your help on the previous occasion.
The circuit digram of the watering systom that I have posted I have built
In the power supply section the +and- 6 Volts is working ok.
The voltage at the 3 Volts DC pins is only 2.5Volts and with load the volts ar
2.5 .
I have replaced the zener diod wich is 3.6V 1W .
I also replaced the R1 200 to 2K2 Resistor.It was smoking.
Where is the problem as the zener should only allow 3.6V
I have to maintain 3V
Gregory is offline
Old 25th October 2006, 10:16 PM   (permalink)
What circuit diagram?
Are you refering to a different thread? If so please post in it rather than creating a new one.
Screen name: Aloone_Jonez
Hero999 is offline
Old 26th October 2006, 10:47 PM   (permalink)
Default Watering circuit
I was able to attach the circuit digram
Gregory is offline
Old 27th October 2006, 03:08 AM   (permalink)
If you designed this yourself, I commend you for trying. If someone else designed it, ....
1. Your bridge is rotated 90 degrees, and is shorting out your transformer (or burning up yout bridge). I suspect it is just drawn wrong.
2. Zeners are even more inefficient than linear regulators. If you make the current-limiting resistors too large, they won't be able to supply enough current to provide regulation. If you make them too small, they and/or the zeners will either have to be physically large, or they will burn up.
3. Your 12V relay seems to be running off 6V.
4. Your electrodes don't have AC passing through them, which I'm guessing is the intent. Also, in that location, they won't provide a signal to comparator .
5. Does the 3V supply provide power to the accompanying logic?
Ron (aka Rube)
Roff is online now
Old 27th October 2006, 03:45 AM   (permalink)
A 3.6V zener diode has such poor voltage regulation that the manufacturers don't show curves for them anymore.
Look at the datasheet. The 1N4729 is 3.6V with a current of 69mA through it. With this circuit's very high 32.5VDC supply, a resistor feeding it should be 419 ohms and will dissipate 2W of heat. With the 2.2k resistor feeding it, its current is only 13mA and so its voltage might be only 3.0V, then the 3V output is about 2.3V. The zener's voltage will drop more as the BD139 transistor takes current from it. Therefore the 3.0V output will not be 3.0V regulated.
Of course the 200 ohm resistor smoked if it was small, it was heating with more than 4W.
The electrodes don't do anything. The output is the same if they are shorted or open or anything in between.
audioguru is online now
Old 27th October 2006, 11:03 PM   (permalink)
I've seen a similar circuit before on these forums but I can't remember where, can anyone else remember this?
Hero999 is offline
Old 27th October 2006, 11:22 PM   (permalink)
I found the same circuit in the OP's Profile, other posts.
We gave him the same answers there too.
I need help in designing a circuit chefach Electronic Projects Design/Ideas/Reviews 13 27th September 2007 12:15 PM
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 09:17 AM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 06:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 11:46 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
