Old 24th October 2006, 09:59 AM   (permalink)
Default need help in AC/DC voltmeter
Hello..can anybody help me about making an AC/DC LED Display voltmeter..
Or can anybody give me a site having this project.
I've researched a DC LED Display Voltmeter in this link
http://www.electronics-lab.com/proje...014/index.html
..is there anyone have a schematic modification in this circuit for measuring AC.?.Please..I need your help ASAP!!
Thanks!!!
awan is offline
Old 24th October 2006, 11:24 AM   (permalink)
you need ADC to measure DC voltage (in AC you need rectification) and write a MCU software to correspond to actual voltage compared to ADC binary output
penoy_balut is offline
Old 27th October 2006, 09:01 AM   (permalink)
Tnx...
but, is there a possibilty that you can modify the circuit without using MCU when measuring AC voltages?
awan is offline
Old 27th October 2006, 09:12 AM   (permalink)
You just need a rectifier, and calibrate the meter to read correctly for a sinewave input (as normal multimeters do). Even better would be a true-RMS converter, so it reads correctly for any shape signal - but these are somewhat more complicated and expensive.
Old 28th October 2006, 12:22 AM   (permalink)
use CA3162E and CA3161E if you don't want microcontroller
Old 28th October 2006, 02:42 AM   (permalink)
The DVM project mentioned uses the Intersil/Maxim ICL7107 IC.
audioguru is online now
Old 7th November 2006, 09:24 AM   (permalink)
Tanks a lot!! Are these IC's CA3162E and CA3161E can able to read AC voltages? I looked at their datasheets and I found that the maximum voltage range is only 999mV, how can I modify this so it can support a maximum voltage range greater than 999mV?.
awan is offline
Old 7th November 2006, 12:41 PM   (permalink)
All multimrter IC's measure DC. You add a rectifier to their input to measure AC.
They all measure a low voltage. You add a voltage divider with resistors to measure higher voltages.
Old 7th November 2006, 12:56 PM   (permalink)
as Nigel said, you need rectifier. to measure higher than 999mV, say 999V, use voltage divider resistor 332,667 ohms connected in series with a 333 ohms resistor. voltage drop on 333 ohms is 0-999mV while on the other resistor its 0-999,000mV
Old 7th November 2006, 01:29 PM   (permalink)
Here is a chip that converts RMS values to DC for you:
http://www.rapidonline.com/productin...moduleno=35606
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline
Old 14th November 2006, 08:34 AM   (permalink)
thnx guys..it helps a lot!
one problem left on my project is the rectifier circuit design. Is this circuit suitable enough for my project?
or there are other rectifier circuit you can suggest?
Thnx again..God Bless You all!
awan is offline
Old 14th November 2006, 08:47 AM   (permalink)
by the ways, I want to know what particular value of each parts in the rectifier circuit will I use. Also, I want to calibrate it to 0-220 VAC inputs or possibly higher than that. Thnx!
awan is offline
Old 14th November 2006, 12:10 PM   (permalink)
The simple rectifier circuit will not measue AC below about 0.5V and will have an error measuring below about 5VAC.
The circuit will need at least one attenuator at its output made with a high voltage resistor and another resistor. The attenuator can contain a trimpot for calibration.
Old 28th January 2007, 02:24 PM   (permalink)
im back again,
pls help me how to short circuit the input (0V) in order to adjust the display to exactly 0..
heres the circuit..[IMG][/IMG]
awan is offline
Old 28th January 2007, 04:09 PM   (permalink)
You might not be able to adjust the display to exactly 0 with that old circuit. The many LEDs cause the IC to get hot inside and the heat changes its reading. Modern multimeters use a very low current LCD display so that their IC does not get hot inside.
Simple 0-120VAC bar voltmeter help qsiguy Electronic Projects Design/Ideas/Reviews 8 13th October 2006 10:13 PM
ac/dc converters ALEXfromBrazil General Electronics Chat 4 22nd July 2004 12:47 AM
Digital Voltmeter sam_h Electronic Projects Design/Ideas/Reviews 3 28th April 2004 07:17 AM
voltmeter jcaluma Electronic Projects Design/Ideas/Reviews 3 2nd February 2004 02:51 PM
Voltmeter using EPROMs robchava Electronic Projects Design/Ideas/Reviews 1 17th June 2003 05:49 AM
