Old 23rd October 2006, 10:38 AM   (permalink)
Exclamation y cant i post my query??
it keeps giving me a memory alloacation error?
crush is offline
Old 23rd October 2006, 10:53 AM   (permalink)
You've posted this one! - what are you talking about?.
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 131072 bytes) in /home/httpd/vhosts/electro-tech-online.com/httpdocs/includes/functions_search.php on line 187!!
any ideas?
crush is offline
Old 23rd October 2006, 10:54 AM   (permalink)
I am trying to post this one as a new post:
Hi all,
Built a photodiode circuit (refer schematic Figure 1 - Link below) to recieve pulses - square wave on "on" period 10us with varyin duty cycles incident on the photodiode(BP104).
On testing the circuit, found the output at the trans-resistance amplifier had some ringing at the edges (refer 2nd figure - 1st response). The further the distance of the incident signal from the transmitter, the more pronounced the ringing.
Any ideas as to what is causing this?
* please click on link for all figures and detailed explanantion: http://generous.boy.googlepages.com/...cievingcircuit
was unable to upload onto this page -sorry for the inconvenience*
crush is offline
Old 23rd October 2006, 10:55 AM   (permalink)
ooops sori read it now - i need to make a few posts in order to be allowed to start a new thread!!
Krud.. that doesnt leave me in a good situation at all
crush is offline
Old 23rd October 2006, 04:47 PM   (permalink)
Your transistor circuit is shorting the output of the photodiode.
Every photodiode amplifier circuit in Google that uses the photodiode with reversed bias like yours has the photodiode direct-coupled to the opamp's input without a coupling capacitor. The opamp's negative feedback resistor has a very high value for high gain and is a high resistance bias feed to the photodiode.
The ringing is fixed with a small-value capacitor across the opamp's negative feedback resistor.
audioguru is online now
Old 23rd October 2006, 07:45 PM   (permalink)
What is the purpose of the gyrator?
Ron (aka Rube)
Roff is online now
Old 23rd October 2006, 09:42 PM   (permalink)
the gyrator acts as a constant current source. It has a time constant such that it is not fast enough to react to the incident pulse of IR (10us), hence giving me a low (square wave) signal at the photodiode.
It serves to filter out ambient light or any other form of IR interference.
crush is offline
Old 24th October 2006, 01:30 AM   (permalink)
The circuit works at short distances, so i do not see how the transistor is shorting the o/p of the PD.
crush is offline
Old 24th October 2006, 02:00 AM   (permalink)
The transistor must have DC current through it for it to be a gyrator. It has only the tiny leakage current of the photodiode so it isn't doing anything.
The circuit should have a high resistance feedback resistor for the opamp for high gain and this resistor should bias the photodiode.
Why not use a TSOP IR receiver IC instead of re-inventing the wheel?
Old 24th October 2006, 02:29 AM   (permalink)
My understanding was that the capacitor C1 is charged up and controls the base of the transistor. R1 and C1 have a time constant associated with them.
so when a pulse of frequency of interest (100KHz) is incident on the photodiode, the transistor deprives the diode of supply due to the large time constant of R1-C1.
so if this theory is right shouldnt the "gyrator" (i might be using the wrong terminology) filter out ambient sources of IR?
I do have a high resisitance feedback resisitor R5, or so i thought! am i wrong? in this case i am looking to get a Vout = Iin * Rfb, which is 68000V/A
I want to implement multiples of this reciever circuit. so it has to be cost effective. ( i am also tryin to replace the AD817AN with a cheaper op-amp.. i used it cuz it was handy and it sufficed the rquirements)
crush is offline
Old 24th October 2006, 02:46 AM   (permalink)
I can't start a new thread either so I will post it here...Nigel or any other mod please feel free to move it if you can start it in a new thread. I get the same error as Crush described...
Hello everyone,
I have been doing some electrolysis experiments lately and I need a strong power supply that has a high current (50A or higher) and low voltage of 6 volts. Is there a simple circuit off of 120VAC mains I can put together to make this work easily and cheaply. I think the easiest way would be to use 2N3055 since they are good for 15A, so a few of these together would suffice I assume. I don't know how to go about increasing current though.
Help or Guidance would be really appreciated.
thanks
George L.
George L. is offline
Old 24th October 2006, 02:53 AM   (permalink)
Your very low gain circuit barely works as "FAR" away as only 5cm. Is that anywhere near as good as a modern TV's remote that uses a TSOP IR receiver IC for its 10m range?
Old 24th October 2006, 02:59 AM   (permalink)
For your power supply topic, look at the current gain of a 2N3055. At only 10A its minimum current gain is only 5, and the datasheet doesn't talk about any higher current. It saturates poorly at 10A even with a whopping 3.3A of base current.
Old 24th October 2006, 03:24 AM   (permalink)
Sorry my fault, i must have been more specific. I thought i had written too much already.
The range i require is only 5 cm.
I am transmitting unique ID's:
10us on, 10 us off - ID 1
10us on, 20 us off- ID 2
and so on..
At the moment i am just simply turnin the transmitter on and off with a fixed "on" period an duty cycle. It is controlled by a simple program toggling the pins of a micro which is controlling the mosfet to the transmitter LED.
Photoreciever modules work on carrier frequencies, which would mean i would have to modulate my transmitted signal with a carrier frequency.
so using a module would mean i wld have to shift away from the workings i have until now.
Or is it an easy shift?
crush is offline
Why cant I post? Rolf Feedback/Comments 15 27th October 2006 05:41 PM
LEDs 2nd Post. RayH General Electronics Chat 2 19th April 2005 02:47 AM
All newbies should read before post TheOne General Electronics Chat 1 19th January 2005 07:03 PM
First Post, Basic Questions ... budidharma General Electronics Chat 11 21st November 2004 04:41 AM
