| I want to use the output from an MP3 player to go to a loudspeaker, to broadcast bird song in the field - photography is the name of the game. I am told that the output from the MP3 is too weak to go direct to a loudspeaker, so needs boosting. Lokking at the Maplin (UK) site they list a universal pre-amp (N69AW) which seems to have four wires, and a number of amplifiers again each with four wires. Is this a simple matter of connecting the output from the MP3 to the input of the preamp; output from the preamp to the input of the amp, and the output from the amp to the loudspeaker. As I say, the unit is to be used in the field, so will be battery powered and I would like to have a reasonable range of volume. One unit that is listed runs on 6v- 16v, will the voltage influence volume! It also suggests a 10k log pot for volume control - placed between the signal source and amp, would this be between the pre-amp and amp? | |
| You probably don't need a preamp. The MP3 player will have a high enough signal to feed a volume control connected to the input of the power amplifier. The supply voltage determines the highest sound level before clipping distortion is produced. I don't know if you an hear the harmonics produced when high frequencies are distorted, and I don't know if birds care about distortion. It might scare them away.
| If you don't want to build anything, then just buy a pair of battery operated amplified speakers. You know the sort designed to be used with laptops and small mp3 players? Like these: http://www.maplin.co.uk/Module.aspx?...kers&doy=17m10 But I wouldn't recommend Craplin, shop around you can buy louder better quality speakers for this price of even cheaper.
| I don't think the photographer wants to wear those cheap and crappy tiny speakers for him to hear recordings of birds. I think he wants the sound to be loud and clear enough to attract birds.
| You may well want a "bridge amplifier". A single-ended amplifier (which is very common) working off a 6v supply would be configured so that one terminal is 3v while the other swings from 6v to 0v. So the speaker sees +/-3V. In a bridge configuration off of 6v, when there's no signal both speaker wires are at 3v. But with a signal, one wire will go to a higher voltage and one wire goes lower. So the peak signal is +6v on one wire and 0v on the other, and the speaker sees +/- 6v.
| Yes, you will need it to be clear and natural sounding to attract the birds. A portable stereo CD player might be ok if you can find one with a line in/aux in. Or of course put the bird mp3s onto CD.
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| A cheap car stereo system, providing it has a aux in of course. I wouldn't worry about quality too much as most birds can't hear past 5kHz, just record it onto tap and use a cheap portable cassette player.
| tony-ellis: I'd second Hero999. My son left behind a pair of amplified speakers, battery powered, that were made for a portable radio or CD player. The sound is excellent, all things considered. Someone must still make those. Almost made to order for your application. FYI - the batteries were installed internally but AC adapters could be attached.
__________________ stevez | |
| Audio amplifier question (Butler amplifier) | Optikon | General Electronics Chat | 14 | 23rd September 2005 03:04 PM |
| Low Power Audio Amplifier | indecided | Electronic Projects Design/Ideas/Reviews | 33 | 8th May 2005 04:18 PM |
| CAR AUDIO HIGH POWER SUBWOOFER AMPLIFIER | Dumitrescu | General Electronics Chat | 5 | 1st April 2005 08:34 PM |
| Need Help building a amplifier / audio out of 0-1000 micamps | Byron0254 | Electronic Projects Design/Ideas/Reviews | 7 | 8th February 2005 11:20 PM |
| Audio Amplifier Designing Project | silverferro | Electronic Projects Design/Ideas/Reviews | 3 | 26th August 2004 11:05 AM |
