Old 16th October 2006, 12:22 PM   (permalink)
Default BCD multiplier
Hey guys,this is a great forum instead...!
I need help and guidance to build a one bit x one bit BCD multiplier...!I have google for it and found nothing on it!For this design,i'm am not allowed to use counter and address to use only basic equipment such as mux,demux,ic and basic gates..!Any idea on how to design it?
stanley85 is offline
Old 16th October 2006, 03:41 PM   (permalink)
1 bit * 1 bit multiply = 2 bit answer.
Take the 2 inputs to an xor gate and the output is bit 0 of the answer.
Take the 2 inputs to an and gate and the output is bit 1 of the answer.
Pommie is offline
Old 16th October 2006, 03:52 PM   (permalink)
i still dont get it..!
my question,let say 3 (0011 BCD) * 9 (1001 BCD) the output will be 27 (0010 0111).
How do i combine full adder or other equipment to design a circuit to get the output in BCD?This is wat i meant by one bit*one bit BCD multiplier.Anyone can help me in solving this porblem..!
Thanks for your reply..!
Old 16th October 2006, 04:53 PM   (permalink)
do u need multiplier circuit which multiply two four bit number and gives answer in BCD form
shahzad-h is offline
Old 16th October 2006, 04:57 PM   (permalink)
yeah,if it is possible,i'm interested to see the circuit..DO you have it?
Default 4 bit multiplier.
Hi Stanley85,
If one of the two 4-bit words is "0" the result should also be "0".
If one of the 4-bit words is "1" the result should be equal to the
other 4-bit word. If one of the 4-bit words is "2" the result should
be equal to the other 4-bit word, but shifted one position to the
left. If one of the 4-bit words is "3", the result should be equal to
the other 4-bit word, but shifted one position to the left and added
to this 4-bit word. If one of the 4-bit words is "4", the result is equal
to the other 4-bit word, but shifted two positions to the left. If one
of the 4-bit words is "5" the result should be equal to the other 4-bit
word, but shifted two positions to the left and added to this 4-bit
word, and so on . . . .
The final circuit will have eight inputs and also eight outputs.
I really don't have a clue what this circuit should look like, I got my
degree by asking questions on forums like this.
on1aag.
on1aag is online now
Old 16th October 2006, 05:01 PM   (permalink)
Originally Posted by on1aag
Hi Stanley85,
on1aag.
I appreciate your help but i 'm not sure i understand bout ur explanation...!DEfinitely the circuit will have 8 inputs but the number is constrained till 9 cause in BCD and the output must be in BCD form as well!I can say that the maximum input will be (1001)*(1001) and the rest which are more than 9 can be considered as "dont care".I just can't figure it out how the circuit going to look like...!
Old 16th October 2006, 05:03 PM   (permalink)
I have the circuit but very complicated containing 80 to 85 logic gates i m not understanding how to post u
Old 16th October 2006, 05:07 PM   (permalink)
wat format the files in...!Are you using any simulator!If it is not a trouble for you,you can always e-mail me..!
my email is ahsiong_world@yahoo.com
thanks a lot!
Old 16th October 2006, 05:10 PM   (permalink)
There are eight inputs which represent 256 combinations. Not all of the combinations are legitimate BCD values. There are 100 valid BCD combinations. For each of those 100 combinations there are eight output values that you can compute. Each of the eight outputs is a boolean function of the eight inputs.
Your task weedhopper is to write down the eight boolean equations of 8 variables. Even after you have done this you wont really know if you are correct unles you build it or simulate it.
Papabravo is offline
Old 16th October 2006, 05:13 PM   (permalink)
IS there any simple way to get the equation without using boolean..!Do you know anywhere i can get the example of the circuit...!100 combination,it will take a long time to get to it right...?
Old 16th October 2006, 05:22 PM   (permalink)
Sorry man that's as good as it gets.
Old 16th October 2006, 05:25 PM   (permalink)
ok,thanks for your suggestion..! still hoping to find the example of the circuit..!thanks ya
Old 16th October 2006, 05:26 PM   (permalink)
Default 4-bit BCD multiplier.
Hi Stanley85,
Shifting to the left is multiplying by two, shifting to the right is
dividing by two. This can be done using multiplexers. The addition
can be done by a BCD full adder like the 74HC583.
Have much fun,
on1aag.
Old 16th October 2006, 05:31 PM   (permalink)
Hi Stanley85,
Have much fun,
on1aag.
opps,havent learn bout that yet!That's why i need example of it so i could understand the whole process of design it...!SOrry for asking,do you know anyplace that i can search for it?
understanding multiplier ckt electronist General Electronics Chat 3 4th May 2005 04:46 AM
4 bit shift and add BCD multiplier arjunarikeri Electronic Projects Design/Ideas/Reviews 6 29th March 2005 12:30 PM
Voltage Multiplier AMalonzo Electronic Projects Design/Ideas/Reviews 8 22nd October 2004 06:49 AM
frequency multiplier? circuitmangler Electronic Projects Design/Ideas/Reviews 2 13th August 2004 06:11 AM
