hi there,im a student.im assigned by my groupmates to create this circuit.i js cant find any information about it.hope any of the members can help me.the frequency adjustable will be between 1-10KHz.thank you.
Do your own work. 1 v0te 4 b1n.
I guess they assigned you this task because none of them have a clue how to do it. I'll give you help in two steps. Tell me, what is the step response of a series RC circuit when there is no voltage on the capacitor. Tell me, in a series RC circuit with the voltage on the capacitor equal to the supply voltage what is the step resonse when the switch to the supply is opened. Express the results V(t) = ... where V(t) is a function of time, t and Vo, R, and C are parameters. Some other spoilsport will probably just give you the answer in which case you will have learned nothing. | |
Search Google for 555 timer tutorial. I've seen atleast three sites containing such information, there is also an online wizard some place.
| | #5 | |
| | #6 |
I don't think I spoiled it just yet. There is still much for him to do, in order to answer the question or design the circuit. Just point him to the resources he will need, whether he makes use of them is another story. If doesn't come back with some sort of circuit, guessing this is just another 'do it for me' request...
| | #7 |
Can a 555 timer gives 40% of duty cycle? I thought the minimum is not less than 50% with the formula (R1+R2)/(R1+2R2) ??
__________________ bananasiong | |
| | #8 | |
| | #9 |
Huh! I didn't know that! What I've learned is up to 50% of duty cycle only. How to make it? Is it set to 60% and then put an inverter at the output?
| | #10 | |
But, like I said, it's EASY to make the mark/space fully variable - I'll give you a hint - 'two diodes'. | ||
| | #11 |
You can bypass one of the resistors with a diode to get <50% duty cycle (see datasheet). Anyway having a variable frequency from 1kHz to 10kHz with a fixed duty cycle of 40% isn't as easy as just bulding a simple 555 timer oscillator. I think a schmitt trigger oscillator will do the job, failing that a variable 50% duty cycle 555 oscillator with a comparator on the timing capacitor will work for sure.
| | #12 |
Yes I found it, thanks. I didn't notice that. The other diode is optional right? So the frequency calculation will be different?
| | #13 |
to vary duty cycle in 555, make a different resistance for charge and another for discharge.
| | #14 |
i manage to figure out how the circuit will look alike.but still working on the values of the components.the other information given to me is: >The output should have an adjustable linear output voltage range of between 0 to 5 V and be capable of supplying a current of 150 mA throughout the voltage range. | |
| | #15 |
There are many ways to do this. I would just add a 100ohm potentiometer followed by a complementary push-pull emmitter follower on the output.
| 40%, circuit, circuiti, cycle, develop, duty, generator, square, wave |
| square wave circuit | townsvillian | General Electronics Chat | 21 | 29th September 2009 08:53 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| circuit help: square and sin wave input = square wave output | spyghost | Electronic Projects Design/Ideas/Reviews | 2 | 28th April 2004 02:09 AM |
| LC filter- filtering a square wave to sine wave | kken6248 | General Electronics Chat | 3 | 22nd April 2004 05:32 AM |
| Circuit to convert duty cycle of PWM to resistance...HELP! | Jerry Miller | Electronic Projects Design/Ideas/Reviews | 8 | 11th March 2004 09:50 PM |
