Hi, I was told that it is very difficult to make a radio. Even I open the radio, the IC's inside cannot be found easily. But I've found a very simple circuit for FM receiver, no IC required, and only a single transistor. I'm not sure whether this transistor works or not, I'm going to try this out. Have you guys seen this before? This is the original circuit: ![]() And this is the audio gain improved: ![]() Thanks
__________________ bananasiong | |
It is a regenerative or super-regenerative simple radio receiver. Read about its problems in Google. It is too simple to be a real radio and is just a cheap child's toy. Another guy was in this forum and for hundreds of posts about it he couldn't make it work, except to pickup the sound from a powerful TV station very close to him.
Okay, Thank you so much.. It's pointless if I make a radio which can pick up the tv sound.. ![]() anyway, what is a rfc? I've seen this in VHF module. what's the different between this and the inductor of the same value?
An rfc is an inductor. Its function is to choke radio frequencies, so it is called a Radio Frequency Choke.
I do not think it is pointless to construct such a radio - if the point is to learn. It is not a replacement for a good design that has been well constructed and the performance will be poor at best. It is fair to say that this kind of radio represents what many used in the early days of radio. During those early days there was far less RF junk. The full attention of a skilled operator might improve reception but there are limits. I do not think that the construction of a good radio is within the capabilities of a beginner or even most advanced hobbyists - if "good radio" is defined as what might be commercially available today. Some can do it but not a large portion of that group.
__________________ stevez | |
| | #6 | ||
__________________ bananasiong | |||
| | #7 | ||
__________________ Uncle $crooge | |||
| | #8 |
I've seen inside the radio, the tuner consists of 4 and some 2 variable capacitors inside. Can I use 2 (or 4) single variable capacitors to do perform the same job? For this type of capacitor, every capacitor in it has to be tuned? What is a high impedance speaker? As I know, many speakers are rated as low impedance, less than 10 Ohm. Can you tell me which part of the circuit is tank circuit? Are they C1A, C1B, C3A, C3B and L1?
| | #9 |
The circuit you found uses two variable capacitors in series with two 10pF capacitors. They can all be replaced with a single variable capacitor, about 5pF to 40pF. You should replace the TL431 circuit with a real audio power amplifier IC like an LM386 that can drive a real low impedance (8 ohms) speaker. The "tank" is the coil and the variable capacitance in parallel with it. At 100MHz, stray wiring capacitance adds to the total capacitance.
| | #10 | |||
I can replace 2N4416 with BF256 right?
__________________ bananasiong | ||||
| | #11 | |||||
__________________ Uncle $crooge | ||||||
| | #12 | |
What is the voltage to the earphone? Very low? I've just bought some variable capacitors, they have 3 pins, are their functions like variable resistor? Short the center with one end? Let's say I have 10pF variable capacitor, can I add another 10pF capacitor in parallel so that they give variable value from 10 to 20pF?
| | #13 |
Look on the datasheet of the LM386 and it will tell you how to connect it up.
| | #14 |
Should I choose amplifier with the gain of 20? Should R1 and R5 be removed? What is the voltage to the earphone? Very low? My variable capacitors have 3 pins, are their functions like variable resistor? Short the center with one end? Let's say I have 10pF variable capacitor, can I add another 10pF capacitor in parallel so that they give variable value from 10 to 20pF? My frc has only 3 color code, the last one is 10 to the power of -ve? Thanks
| | #15 | ||||||
Use the LM386 with a gain of 200 and add a volume control. A radio is useless without a volume control. Quote:
__________________ Uncle $crooge | |||||||
| radio, receiver |
| Sabotaging a short-wave radio receiver | Odysseas | Electronic Projects Design/Ideas/Reviews | 15 | 17th October 2006 04:31 PM |
| Need transmitter & receiver IC nos for radio transm | Jtron | General Electronics Chat | 0 | 20th April 2004 06:38 AM |
| world space radio receiver project | ks_raman | Electronic Projects Design/Ideas/Reviews | 1 | 27th August 2003 12:17 PM |
| radio telemetry receiver mod. | raycalvino | General Electronics Chat | 2 | 13th June 2003 09:06 AM |
