Old 13th October 2006, 10:54 AM   (permalink)
Question 4541 timer question.
i have built this 4541 single shot timer ranging from 15m to 8hrs. The output remains low and goes high after set time.
How can i get notification that oscillator /circuit is working properly when the timer starts.???
regards
muddasserniaz is offline   Reply With Quote
Old 13th October 2006, 12:40 PM   (permalink)
I don't understand why you have a resistor from pin 6 to ground. The spec sheet says it should be at 0 for timer operational or 1 for master reset. Since you have it programmed for power up reset and single cycle operation, you can assume with the output a 0 it is functioning properly when you apply power. I would recommend that you only change the dip switch setting for capacitor selection when the power is off.
k7elp60 is offline   Reply With Quote
Old 13th October 2006, 07:06 PM   (permalink)
You could monitor the internal clock with a small MOSFET (2N7000, 2N7002), an LED, and a current-limiting resistor. Gate to pin 3, source to GND, drain to LED-resistor series combo, other end of LED-resistor to VCC.
Ron
Roff is offline   Reply With Quote
Old 16th November 2006, 03:54 AM   (permalink)
Default Accuracy and Frequency questions!!
thanks ron , oscillator monitoring led is working great with 2n7000.. !!
i have some more questions regarding 4541 operation.. plz help!!
1) what's the lowest frequency possible/recommended , although datasheet says the fx should be between 1khz and 100khz i have used it at 1hz and its still working ....but when fx is lower than 1 it is not working.
some say that 4541 can be used for timing delays of days but i am not sure how it can be achieved without fx lower than 1hz.
2) keeping in view the component tolerances how can i achieve best accuracy??
Old 16th November 2006, 06:59 PM   (permalink)
Sorry, I've not used the 4541. Maybe someone else can help.
Ron
Old 16th November 2006, 11:51 PM   (permalink)
For accurate long time delays I would use a CMOS 555 as you can use up to about 20M of resistance for timing. But use a good quality film capacitor. You could still use the 4541 divider. I have used the 555 and cascaded 4060 14 bit counters for extreemly long delays.
Old 17th November 2006, 12:11 AM   (permalink)
The datasheet for the CD4541 says you can operate the clock oscillator as slowly as you want. Then you can use its divider to divide by up to 65k.
Old 18th November 2006, 07:00 PM   (permalink)
regards
Hi
i understand your doubt as how to know the cct is functioning or power failed --something-- in fact you might have notices that 4541 can output either Q or Q*
if you select by defining the select pin you get a high sinal when the timer is ON . Hope this helps
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Zilog Z8 timer question meratz Micro Controllers 4 12th October 2006 03:22 PM
IR EMMITTER AND DETECTOR, USING 555 TIMER (TESTING QUESTION) Anton04 Electronic Projects Design/Ideas/Reviews 1 2nd November 2005 05:50 PM
555 Timer, Astable Mode Question micro571 Electronic Projects Design/Ideas/Reviews 3 17th October 2004 04:25 AM
Question about the 555 timer xenoxion General Electronics Chat 4 22nd June 2004 08:54 PM
555 timer question rayclark General Electronics Chat 8 1st October 2003 07:42 PM
