Old 10th October 2006, 11:05 PM   (permalink)
Default Need a quick design A.S.A.P. Ha Ha... right
I want to build a simple solar charging picnic table camp light...just enough to let me know where the table is... I was thinking along similar lines as those walkway solar powered lamps.
Criteria:
Source Power: 3.6VDC NiMH
Light Source: White diode(s)
On/Off switch
Variable brightness
Photo-resistor controlled
Adjustable sensitivity
Charger Power: Solar cells
All the knobs are simple. Essentially I need a charging unit by day and a battery operated light by night. The controls just allows me to conserve energy.
If any of you could draw me up a quick circuit I would really appreciate it!
Brian
iONic is offline
Old 11th October 2006, 12:02 AM   (permalink)
Here's a circuit I've been using and does a pretty good job. Not sure about the 3.6 volts, but should work with minmal adjustments. For 3.6 volt batteries, you'll need around 4.5 volt solar panel.
Adjustable brightness to save battery power... Think the additional circuitry would probably use as much or more, but the PIC guys will disagree...
The parts aren't critical, breadboard it with what you got, and see if it'll do the job, pretty simple.
HarveyH42 is offline
Old 11th October 2006, 12:22 AM   (permalink)
Default My first try???
Any ideas as to how well this might work? Or if it will at all?
Questions:
1) Should the max voltage of the solar cell (in fun sun) be no more than the battery voltage (3.6V)?
2) If so, could replacing D1 (1N914) with a 3.6V Zener diode regulate it?
iONic is offline
Old 11th October 2006, 02:37 AM   (permalink)
Ni-MH cells are charged with current, not with voltage. The voltage from the solar cells after the 0.7V drop by the diode must be high enough to supply the charging current, about 1.4V per cell x 3= 4.2V + 0.7V= 4.9V minimum.
Energizer recommends reducing the trickle-charging current when the battery is fully charged. The fading sun and clouds will do it for you.
audioguru is offline
Old 11th October 2006, 03:02 AM   (permalink)
Here is a circuit from a commerical solar moonlight. It uses the solar cell to sence if it is dark/light and controls the on\off switching of a Yellow LED. Notice there is no current limit resistor for the LED. In the interest of utimate cheapness, the manufacturer relies on Q2s beta and R3 to limit LED current. I've posted this schematic to point out how to eliminate the CDS cell from your circuit. For the transistors you can use 2N3904s.
On another note, NIMH batteries are a poor choice because they don't like to be over charged whereas NICADs will tolerate over charge much better. The NIMHs will overcharge in a bright area (Or Summer) if the circuit is optimized for dimmer (Winter) conditions.
kchriste is offline
Texas Instruments New Design Center. chemelec General Electronics Chat 0 18th May 2006 11:34 PM
Analog design: Some things to remember Roff General Electronics Chat 18 8th November 2005 02:38 PM
anybody knows how to design a calculator??? eleanor Electronic Projects Design/Ideas/Reviews 4 12th August 2005 06:45 PM
Inviting Entries to Electronic Design Contest wasuwathp General Electronics Chat 0 23rd October 2004 04:01 AM
Inviting Entries to Electronic Design Contest wasuwathp Electronic Projects Design/Ideas/Reviews 0 4th October 2004 07:35 AM
