| I am modifying the panel of my car (Fiat Uno 1.5R, year 88) and wanted to make a digital panel with leds or display of 7 segments. Necessary of some projects schematics: Meter of RPM (tachometer); Meter of the fuel level; Meter of the oil level; Meter of the oil pressure; Meter of the water level in the radiator; Meter of the temperature of water of the radiator; Meter of voltage of the battery (voltmeter); Indicating light of march change (shift-light); Counter of current march; Speedometer; Internal light with gradual power off; Turbo timer; Meter air/fuel (Hallmeter); Meter of vacuum; Meter of external / internal temperature (Thermometer) I am thank full who will be able to help me. PLEASE | |
| Many of those signals are analog (metered on the dash) on the car already, so it would require an A/D converter and associated led logic. A PIC would do both. On the items that are not readily analog available (such as water level in the radiator or vacuum), you will have to create some sort of circuit that can either measure it directly, or get it off the car's computer, if that particular data is available to it, which may be quite involved (I am not familiar with your particular car's computer).
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
| For the vacuum use a MAP sensor (manifold absolute pressure) from a chevy engine, 1990s from a junk yard. Easy to work with V+, ground and a variable voltage output. | |
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 03:44 PM |
| what kind a instruments can help him? | vasanthakumar | Electronic Projects Design/Ideas/Reviews | 5 | 2nd June 2006 10:47 AM |
| Help with audio graphic analyzer & VU meters | adrianbodor | Electronic Projects Design/Ideas/Reviews | 4 | 6th October 2004 02:24 PM |
| how do I detect this switch 20 to 30 meters away? | j3Riks | General Electronics Chat | 14 | 19th May 2004 05:16 AM |
| Manuals for an old Advance Instruments scope? | Well Cookin | General Electronics Chat | 5 | 5th November 2003 01:52 PM |
