| Im a begineer. I have two 8ohm 0.25 speakers. I want to use one as a mic and other as a speaker. I have a transformer which can supply AC voltage of 4, 8 or 12 volts from room powersupply. So how can i do this SIMPLY??? | |
| Hi DirectXXX, It is OK to use a speaker as a mic. You will need an amplifier. Connect one of your speakers to the amplifier's input, and the other to the amplifier's output. Amplifiers run on DC. Regards, John | |
| i know about amplifier. But i want to do some low level. I heared you can use transistor in this case with a higher voltage supply. But i dont know which transistor. and where should i make connection with three pins of transistor. | |
| look up simple audio amplifyers. they can help
__________________ Do no meddel in the affairs of dragons, for you are tasty and go good with ketchup. | |
| This link may help. It is very simple. Although designed for an electret mike, an 8ohm speaker would probably be OK. http://www.reed-electronics.com/ednm...=0&rme=0&cfd=1 | |
| Simple for you. But i will try it as soon as i get required components. | |
