Old 29th September 2006, 03:45 PM   (permalink)
Default microscope dimmer circuit
I need help with repairing a dimmer circuit on an old microscope. The bulb is 30 watts and it lights but no dimmer. I apologize if the photos are no good. It is an old style circuit if you can see and I believe the burst grey cannister triac is the problem. Can anyone help with what/where I can get a replacement? It is marked with a line of japanese script and "ES-0001".
Or could I just replace it with a modern say 200v, 6 A triac like SC141B?
Or should I just scrap the whole thing and retrofit a standard wall switch dimmer?
Thanks for any help
dengue
dengue is offline
Old 30th September 2006, 01:22 AM   (permalink)
I dare say it could be repaired but a retrofit would be a better option.
Have you considered using LED illumination ?
This might add new use to an old instrument.
It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron.
The Mad Professor is offline
Old 30th September 2006, 05:22 AM   (permalink)
thanks for your thoughts. I never considered LEDs. Can I impose further to ask for a reference or some leads on designing a dimmable LED circuit? The 'scope was originally and still is, a very capable unit.
dengue is offline
Old 30th September 2006, 05:49 AM   (permalink)
If it were my unit, I'd do exactly what you said. try an appropriate triac first. can't be that expensive. if that doesn't work and there is space, use the premade dimmer. LEDs are fun to play with but it will be a lot more involved than the other two options.
philba is offline
Old 30th September 2006, 08:00 AM   (permalink)
Actually, your pictures are better than most. Just try any old triac that has a suitable raiting.
There are a crapload of simple dimmer circuits out there (hundreds were found with 1 google search) if you just wanted to start from scratch..since you seem to have quite a bit of space to play with. You can use just a standard wall dimmer as well
SHYTE!
bigkim100 is offline
Old 30th September 2006, 03:46 PM   (permalink)
Since it's low current a TICP206 will probably do, they're very cheap and quite reliable too. I have loads of these in my junkbox, they're very handy.
Screen name: Aloone_Jonez
Hero999 is offline
Old 30th September 2006, 04:58 PM   (permalink)
Excuse me if I am being a bit thick here, but, all the triacs I have ever seen had three connections and came in either plastic or metal packages much like other semiconductor devices.
Things which come in grey plastic wrapped cylinders with two wires look like capacitors to me.
JimB is offline
Old 30th September 2006, 06:51 PM   (permalink)
You might be right but I've seen some very wierd looking transistors before. I've got some that look like capacitors, they are metal cans covered in red sleaving but I'm sure they're transistors.
Hero999 is offline
Old 30th September 2006, 09:02 PM   (permalink)
Post a picture of one then! - I'm sure we'd all love to give an opinion?
I also agree that the picture at the start of this thread looks more like a capacitor than anything else - specifically a mains interference suppressing capacitor. It's also the sort of component which is likely to blow a hole through it's side!.
Old 30th September 2006, 09:54 PM   (permalink)
Lightbulb
Hmm...I'd also say that the grey thingie is a capacitor cause of the big hole in it : lol. But I've said about a cap in a pic that's a coil :lol.
About the main problem....Just remove the old components and put something like 4Xwhite leds (I've seen some 5mm/13000mcd @ 20 degrees angle and <.5$) comanded by a variable curent source made with a LM317. de 2X2 goup uses max 80mA @ 3V.
For power supply use a cheap adaptor at 6V or 7.5V and 2&2 leds in series.
If is too complicated.....most of the times is the wrong way.
Tarsil is offline
Old 30th September 2006, 10:58 PM   (permalink)
wow - thank you all for the feedback. sorry to break up the transistor capacitor triac debate, but it's my bad photography that did it. The blown grey beastie has 3 wires:blue red and brown.
If I replace it with a TICP206 as hero999 suggests, where should I place a fuse to prevent it from blowing up again? thanks
dengue is offline
Old 30th September 2006, 11:19 PM   (permalink)
Nigel,
I'd love to post a picture but I can't find my digital camera.
dengue,
Place the fuse on the phase/live/hot conductor series with the whole circuit.
Hero999 is offline
Old 1st October 2006, 11:20 AM   (permalink)
Check EXACTLY where the wires from it go, three wires is common on mains suppression capacitors - it doesn't resemble a triac at all?.
Old 1st October 2006, 03:41 PM   (permalink)
Looking through the hole in the side of the grey cylinder, there appears to be a coil, judging from the colour. Could this thing be a mains filter?
JimB is offline
Old 1st October 2006, 07:09 PM   (permalink)
Exclamation
How about taking the circuit apart an replacing it with a modern version. The circuit itself is quite hard to repair not knowing what every part does (grey or not ).
After that u can post a lot of pictures of the canister for easier identification. U realy want to rely on a....30 Y old pot, cap etc.?
Tarsil is offline
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 31 13th October 2008 05:35 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 04:07 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 02:45 AM
Dimmer circuit help subzero349 General Electronics Chat 1 25th July 2003 02:37 PM
