hi guys, need help finding a variable current driver circuit. thanks in advance Pao | |
Again, give more information - such as what range of current, and to do what!.
i need a 0-20mA variable current driver that a sawtooth waveform of 250hz and 1hz and a squarewave of 1-100hz can pass. Ranging from 1-10V. I need it cause i have a project or should i say for extra credit to make a dead frog leg kick using the schematic below but apparently it lacks current seeing that it only powered by a LM324. I know what you guys are thinking why not change the whole circuit instead of putting a current driver right? Well one reason is that the hint/ requirement my teacher gave is that we cannot change the said circuit. And 2nd I have no background or idea on how a current driver works, its a good opportunity to learn. Although Im currently researching for it. so thankz | |
What's the reason for IC10?, presumably it's supposed to be a constant current source?, but isn't your whole objective to provide a varying current?. However, a simple NPN transistor, base to the three diodes, collector to +12V, will provide a higher current drive from it's emitter. | |
IC 10 was supposedly a current limiter of 20mA but it doesn't work.
| | #6 | |
| | #7 | |
got any suggestion on NPN X'sistor i could use i found this NZT651 but Im not too sure. | ||
| | #8 |
Any small signal NPN should do, and use a resistor for a current limiter!
| current, driver |
| Resistors | Marks256 | General Electronics Chat | 57 | 16th May 2009 11:22 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 01:50 PM |
| Discrete Pulse width Modulator... | Rajagopal87 | General Electronics Chat | 8 | 16th August 2006 06:25 AM |
| Current Source and current mirrror | lord loh. | General Electronics Chat | 12 | 25th April 2006 09:52 AM |
| Will this work? | daviddoria | Electronic Projects Design/Ideas/Reviews | 31 | 9th May 2003 05:43 AM |
