Old 20th September 2006, 12:57 PM   (permalink)
Default Gear Indicator.(need help to build one)
Hello all.
I'm new here and my understanding in electronics/programming is zero!.(also sorry about my English)
I need help with building a gear indicator to be install in my car with a seven segment display that show the 1-5 /R gears.
The idea is when I shift a gear I will see the number of the gear that im using on the seven segment display until I will shift to another gear.
for example: im driving in second gear...I see the number 2 on the display until I will shift the gear to third gear and than I will see the number 3 on the display.
Because my understanding is very poor in electronics I was thinking about a simple board with six microswitches,1-5 gears and "R" for the reveres gear.each switch will show a number when I press it...but..the number will remain until another microswitch is press.
Any help with this idea will be great!!!
Thank you very much!
Guy.
zx16v is offline   Reply With Quote
Old 20th September 2006, 02:01 PM   (permalink)
A simple way is to use a PIC, which is a small programmable 'computer' on a chip - you could program it to do what you want, and it would be a one-chip solution.
Old 20th September 2006, 02:16 PM   (permalink)
Thanks for your replay,
Because of my ZERO understanding in electronics i guess that even the simple way to make it for me it will be too complicate to make this chip or any other circuit,do u know if there are kits like that to buy?
Guy.
Old 20th September 2006, 02:31 PM   (permalink)
If someone can make for me this circuit it will be GREAT!
Guy.
Old 20th September 2006, 04:35 PM   (permalink)
If you don't know how to program a PIC, here is a modification of a circuit I designed for a guy who wanted 0-6. As shown below, it will indicate 0-5. You can change 0 (reverse) to some other character very simply.
You will have to come up with a switch closure for each gear. If you can't do it mechanically (microswitches), it could possibly be done with magnetic sensing (Hall effect devices).
Ron
Roff is offline   Reply With Quote
Old 20th September 2006, 07:34 PM   (permalink)
Thank you sir for the schema.
Guy.
Old 21st September 2006, 03:05 AM   (permalink)
an old analog joystick pot control to do the sensing might be easier to mechanically couple to the gear shift lever, just a thought...
tunedwolf is offline   Reply With Quote
Old 21st September 2006, 11:08 AM   (permalink)
Don't forget that reed switches may be an option too.
RODALCO is offline   Reply With Quote
Old 21st September 2006, 11:14 AM   (permalink)
Hi guys...thanks for your replays..the problem is that i can't do anything with this info because i dont know anything in electronics,
im looking for someone with time and good weal to build for me this circuit.(if its not expensive..i will pay for it)
Thank you very much!!
Guy.
Old 21st September 2006, 03:44 PM   (permalink)
Guy.
As I pointed out in my PM, you really need some local help. How about asking for help from a college engineering student?
Ron
Old 5th October 2006, 08:38 AM   (permalink)
Thank you sir for your B I G help with my first circuit,its working GREAT
Old 6th October 2006, 04:51 PM   (permalink)
In response to some requests by PM from zx16v, and another PM from yassirau, I am posting another version of the gear indicator. It is far from being a minimum-hardware design, so don't rag on me about the large number of diodes! It avoids the need to learn to program a PIC, and, for those who may not have easy access to components, uses a minimum of different component types.
This design uses a common-cathode display, and has indications for 0 (reverse?) through 5, and uses "-" to indicate neutral. The "0" can be changed to some other symbol by changing the connections of a few diodes.
Ron
Old 6th October 2006, 04:54 PM   (permalink)
No problem Ron, it's simply a hardwired ROM, which is what a PIC solution would be simulating.
Old 7th October 2006, 06:08 PM   (permalink)
Great, i will give it a try and let u know.
Thank you sir!
SMPS power suply modify or build plss Raducu General Electronics Chat 12 9th February 2006 12:52 AM
Plastic gear from hourmeter 2PAC Mafia General Electronics Chat 2 13th December 2005 03:36 PM
Need help to build firebot anand_jain Robotics Chat 7 22nd September 2004 01:48 PM
Gear Indicater PyRo1509 Electronic Projects Design/Ideas/Reviews 6 4th May 2004 12:38 AM
Motorbike Gear Displayer Help and Ideas L3wis Electronic Projects Design/Ideas/Reviews 23 15th September 2003 07:59 PM
