I am trying to get a 4-bit data sent by mobile (Nokia 3310), using DTMF decoder MT8870 through the headset.
That is in short my project. I am in the stage of components collection. Is it possible to get this project work or not? Please all your advice is appreciated, and any small tips may make difference. salam Last edited by aljamri; 16th September 2006 at 05:42 PM. Reason: To make title more meaningful |
I worked for Mitel (MT) for 15 years. You lost me on the "through the headset".
Can you give more details? |
Sorry, this shows how much I don't know about the subject. I'm trying to connect the mobile earphone wire into the decoder input terminals, and I'll put my mobile on auto answering mode ( after 3 rings) then I'll press the numbers of my mobile to give beeps, is that signal clear and strong enough to be decoded or not? Thanks for trying to help me.
salam Last edited by aljamri; 19th September 2006 at 02:03 PM. |
There are many DTMF decoders. Ramsey has a kit based on another chip. Or check this one out.
http://www.geocities.com/constantine...ntent/dtmf.htm All pic version. What is the range you are tring to control things from? A 2 mile walkie-talkie would save on the monthly phone bill. Make a DTMF generator and receiver. |
Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." |
(permalink) | ||
Regardless all of these things, building a project and seeing it functioning is a great childish pleasure I'm ready to lose money for. Thanks a lot
Its what your friend in Your mind, what you in your friends mind |
Should be a challenge. I assume the phone is in a good environment, your auto-answer will get amplified to a DTMF decoder. Then a PIC of something will process the digits and do something?
Did you see the PIC only DTMF page I put up? |
mramos1 for sure I'll need your suggestions during my progress in PIC study and many of my doubt will need your valuable answers thanks again and again
Its what your friend in Your mind, what you in your friends mind Last edited by aljamri; 24th September 2006 at 07:00 PM. |
Even with the 4 bits from the DTMF decoder, you will need to read them and have a processor deal with them, if you are doing real control apps.
Also have an interface to the decoder chip. Is this is a school project? Maybe just light up 4 LEDs. So you are in the 6th grade? Wish my kids here in the US were doing electronics in the 6th grade. I have scopes, just sold my 8051 emulator. PICs and Atmel chips and programmers all over.. They like sports and video games. I will fix the video game part soon though.. Too many hours wasted. |
I tried to measure the frequency for different digits using my FLUKE 79 with Hz meter but they seem not stable and nearly the same, that's may be because its composed of two frequencies. Any Idea.... Any body...? thanks for all
(permalink) | ||
(permalink) | ||||
thanks a lot..
When I tried to measure the frequency the same way, I could not get stable readings. After many attempt I got no any two similar readings. However, it is clear that there is a range started from almost 600 Hz (Key 1) up to 1.1 kHz (key 0).
Its what your friend in Your mind, what you in your friends mind Last edited by aljamri; 25th September 2006 at 02:29 PM. |
QUOTE=akg]i would suggest you to construct the decoder and work with it , rather than fiddling with the o/p signal strength too much. after all , as suggested above , if reqd we can very well amplify that. well my concern is ,if you send a sequence of tone to the mobile and there is signal fading , then the decoder will miss some tones , that can cause unintentional working of your device.[/quote]
thanks for your series of replays that made me more excited. I like it when you used We in your replay this is one reason why I enjoyed being a member Electro Tech this what i call Team Sprit about service shading I don't think it is big concern since I need only a press to just one key to control the process. In later stage I'll use the mobile mic ( not earphone ) to give sort of feed back. But let us keep this for later discussion. thanks and bye for now
