Does anyone have a simple circuit of induction cooker/ heater? I got a 400KHZ 60KW but the parts are very expensive and to hard to find.
INDUCTION HEATER
400KHZ 60KW
Triode YD1172 - $1249.99
HELP ME PLS!!!!
Thanks in advance,
INDUCTION HEATER
400KHZ 60KW
HELP ME PLS!!!!
Thanks in advance,
Are you serious? 60 kw is the same order of magnitude as a 60 hp motor.
It is unlikely that this can be done simply and inexpensively with easy to find parts - unless your definition of simple, inexpensive and easy to find is quite different than my own.
stevez
We use Lepel Units at my work; try their website:
http://www.inductionheating.com/
Here's my circuit. Can somebody give me a much more simpler than this. Says 2.5kw
Thanks in advance
It could hardly be any simpler, there's next to nothing there! - but you've also drawn it wrong!.
To expand on what is wrong with the circuit:
The anode voltage is rated at 7.2 kV maximum, so 6 to 8 kV will not do.
The thing which I assume to be your cathode current meter is likely to be fried by the 130amp filament current.
There are no DC paths to either the anode or the grid.
As drawn, it is not going to work.
i have all the components of electronics can u send me the components list
i could quote the best price of it for u
send me the list as soon as possible on kansara_nitish@yahoo.co.in
nitish kansara
919727930969
Hi every one, since it's my first post, let me introduce myself.
First I'm from Québec/Canada, french speakig so excuse my english.
Computer technician and electronic addict.
Now here's what i need.
I'm currently working at an induction heater for my purpose of casting parts( robotic)
I did quite well with a static circuit but want to achieve a feedback loop so the resonant frequency adjust itself as the metal cruciform come in the work coil.
PLL is not really my force.
Thank's
dnsmaster You should post this in a new thread, not in someone elses, even if it's related.
straight answer, har har."
Oupss.... Thanks for the advice!
