| "In this project, requires to design a model of missile, which controlled by the PC. At first, the target is designed such a way that it continuous sending signal with constant frequency. The missile is designed such a away that it can capture the target signal only. Once it has processed by the PC, the user press "enter" key to launch the missile. So, whenever the target is going, the missile will keep on follow it till mission completed. The software used in VB (Visual Basic)/ The VB should obtain the target signal, and then send the signal back to the missile after processing. VB also will trigger the missile." Missile can be replaced by a guilded toy car or something else. I think the main objective in this project is the tracking signal system. Can i have some ideas on this project from you guys - experts. Thanks.
__________________ Dreams may come true. | |
| I'm not an expert, but I'm guess you know the target frequency/signal. So, you will need to build a small scanning antenna to find where the strongest signal is coming from. You would shield it so it can only recieve from one direction. Once you lock on to the target, you will need to determine distance, although may not be important to your project, just the direction. If this is for indoors, you will most likely have fun with reflections off the walls. If the target is mobile, you will need the computer to track. This stuff could be done with software, but not my field, and likely take some work. Basically, I'd guess that when the signal deviates frome the origional lock, need to re-scan the area, or just a few degrees to each side to re-establish the strongest signal direction. You will need to sync the antenna direction to you 'missle', more software. The programming of the antenna and 'missle' will be very hardware dependent, so you will need to build a bunch of crap, before writing code. Computer interface several transmitters/recievers scanning antenna target missle This project would take a while, even with a team of experts. | |
| I might be thinking of: three different targets designed in such a way that each of them generating its own signal. Therefore, the guided "missile" can choose the specific targets. The target is somehow mobility. Thanks for your advices and helpful ideas. Mr. Harvey.
| THis should actually be quite funny...Ill be looking for the hedlines over the next few months..." Kuala Lumpur terrorists build, and fire a missile, shooting down a Jumbo Jet. Checking the files of the terrorist groups computers came up with a American co-conspirator in Florida by the name of Harvey. Mr. Harvey was found to have assisted the terrorists in the design of their guided missile, contacting the terrorists thru a electronics newsgroup on the internet" Say howdy to the FBI when they come to your door. I hear that they go a little bit easier on you during yiur full Rectal examination when your friendly to them.
__________________ SHYTE! | |
| Americans are mere amateurs when it comes to severe and bizarre punishments. You can get canned for spitting on the sidewalk in that place. It's definitely off my list of vacation spots. | |
| Didn't know Malaysia was a hot spot for terrorist... It sounds more like a robotics project, honest mistake... This is going to be very difficult to do two axis ground based, a third axis for airborn targets? You guys need to consider some anti-anxiety medication... I did remember a sight that had a robotic sentinal. Automatically detected movement, aimed and fired an air rifle, even tracked the target and kept firing at it. Computer, camera, and servos. Pretty cool. | |
| It's easier to stick a heater on the target and use a thermopile to follow it around...tracking the origin of RF signals is really hard. Maybe you could follow cats or people around instead. | |
| The Americans finally got their missile tracking and shoot-down system to work. This terrorist missile will be shot down too.
| | (permalink) | ||
__________________ I'm could be wrong many time's, at least I know what I'm doing. | |||
| Does Canada have a military? Don't recall every hearing anything in the news, always figured if canada had problems, America has problems, and we go save your butts. | |
| You didn't hear that there was another friendly fire incident in Afghanistan? One soldier died and 8 others indjured. | |
| sheesh, is this the "how many nationalities can you insult in a single thread contest". By the way, PB, you are thinking of Singapore. It is a fine city. $50 fine for this, $100 fine for that... | |
__________________ Dreams may come true. | ||
| well, howl, think about how you phrased it. "guided missile". I don't know about you but I bet most people think "weapon" when they see those words. And no, I don't think it's funny, either. But I'm sure it is for a different reason than yours. | |
