Hello, I've been trying this for a while (about some weeks). I built a mosfet driver to drive an ignition coil. The first driver I've built was very simple, and the mosfet didn't turn off fast enough to generate the "kick effect/auto-inductance/back emf" (I don't know how do you call that ) so high voltage was not generated.I could see that the MOST was not switching off, because I was using an 20A ammeter between the drain and the coil. I tried with 2 mosfets, IRF3205 and IRF740. Fail #1: Sparks were not generated. Mosfet didn't turn off. ![]() Fail #2: Some weak sparks were generated. Mosfet didn't properly turn off. (I could improve the performance by decreasing R2 value (10k) to 300R) ![]() Fail #3: Strong sparks were generated. After a few seconds of working, the mosfet starts to conduct alone. So I have to turn off the supply to "reset" the circuit. ![]() Any ideas? | |
What voltage are you using for the signal? Use a push pull trigger signal source like a 555 timer, and at least 10V for the signal and reduce the resistor in series with the MOSFET's gate to 10R or better still, get rid of it and use a small ferrite bead.
| | #3 | |
I'm using a 555 timer as signal source. The signal is about 11V. You mean, use a ferrite bead as a resistor? Or to make a "little transformer"? | ||
Put MBR1645 or similar in the primary of the transformer (+ at + supply and - in the drain) Industry Number : MBR1645 R-SCHOTTKY, 45VOLT, 16AMP, TO-220 Last edited by muki55; 7th September 2006 at 02:15 AM. | |
| | #5 | |
To protect the MOST against back emf, isn't it? But I still don't think that it's the cause of my problems. | ||
| | #6 |
Just try it!!!!!!!!! and here's the working one but not mosfet output it's (2N3055) output. | |
| | #7 | |
I simply gave up using 2N3055, I had to parallel some of them, and they did not heat equally (I was using 0.5 ohm ballast emitter resistors). | ||
| | #8 |
Maybe this one will help. If not: Try tesla circuit. (Just joking) Here's my last one trying to help You. I'm Tryingggggggggggg. hu! hu! hu! hu! hu! C1- 1uf/200v Last edited by muki55; 7th September 2006 at 03:47 AM. | |
| | #9 | |
Thanks for the helps, but I prefer to design the circuit myself. To take someone else job is not funny. | ||
| | #10 | |
To fix this, you must apply symmetric postive and negative going pulses to 'reset' the magnetic core of the transformer. Many times, you can also use a free wheeling diode to provide the reset. Another method would be to lower the duty cycle so that the transformer has sufficient time to dissipate its magnetic energy. When the switch opens, the transformer's primary will automatically generate a reverse voltage, but if not enough time is allocated before the next pulse comes in, it cannot fully discharge, and will eventually saturate - which you have witnessed first hand.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | ||
| | #11 |
I've worked with some mofsets that needed -ve volatge to force them to switch OFF. if you have a pulses signal (0 - 5v) you can easily transform it into (10 , -10v) using a cheap 741 opamp. this is what i did, i was using the mosfet to drive a highly inductive load, and it wouldn't switch off, and that was the solution.
| | #12 | |
I don't think that the core saturation is the problem, because it works fine with power transistors like 2SC4106. But I'll try to add the diode. Another thing that is driving me crazy is that I've paralleled 2 MOSFETS and they are heating unequally, when I say unequally is: One is cold another is very very hot to the touch. ![]() (CORRECTED THE SCHEMACTIC) Another thing I've noted is that one of the MOSFETS is heating w/o signal applied. I don't know what it is, because it's the second time it happens, I don't think I'm so unlucky to get 2 pairs of mosfets (each pair in a different radioshack) with 1 deffective mosfet on each pair. Last edited by Hayato; 7th September 2006 at 05:13 PM. | ||
| | #13 |
Has anyone pointed out that collector and emitter need to be swapped on the BC327? Having said that, if you are generating the pulses with a 555, it will probably provide higher drive current than you will get from push-pull emitter followers, and you will get 1.4V more gate drive. And what is the purpose of the zener? | |
| | #14 | |
What do you mean by swaped? Is this (for example): BC337: EBC BC327: CBE I didn't do that because the datasheet, from fairchild, says that BC327 and 337 have the same leads configuration. (I thought that was strange, but it's the datasheet). The purpose of the zener is to protect the gate from any voltage higher than 12V. | ||
| | #15 | |
| mosfets, properly, switch |
