Hello, I am currently building myself a power amp for my bass using a Velleman kit, http://www.velleman.be/ot/en/product/view/?id=360242 , and other bits and pieces. What I would like to know is: if i remove the entire preamp section from my Laney guitar amp, would it still be compatible with a bass guitar? ![]() Also, the preamp board would, I guess, need a few components replacing or removing (all I'm basing my idea on here is a project at http://sound.westhost.com/project27.htm#bass ). A final question, could I run the preamp off the power transformer which is providing for the amp - without a significant power drain? Because (being a bass) I really need as much power to the amplifier as possible.. Transformer rating is [230vac in, 160vac out = 2x30v, 2x2.66A] part no. N04BA from Maplin Thanks | |
I would suggest that amp is a bit under powered? - with only a single pair of TIP's I wouldn't advise using a lower speaker impedance than 8 ohms, so you're looking about 60W or 70W into 8 ohms. Bear in mind bass needs plenty of power! - if you're talking acoustic drums, and single 12 inch speakers, 120W for bass and 60W for guitar balances quite well. For a simple (and popular) bass preamp I suggest you look at http://www.albertkreuzer.com/preamp.htm. No problem powering it from the main supply, preamp power requirements are quite low, it's commonly done in that way - using crude zener stabilisers and wirewound resistors. | |
I agree with Nigel, seems a bit underpowered, low headroom. You may have heat problems as well.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
Yeah I know about it not being very powerful, but to be honest it was just gona be a temporary-ish amp for until I can afford something better. As for heat, I'm going to order a 0.75c/w heatsink and mount a fan with it. However, would it be possible to replace the power transistors with more powerful models? | |
| | #5 | |
If you want the amp to produce more power into the speaker you have, then increase its supply voltage and replace all the transistors to match the higher voltage. Probably most of the resistors would also need to be bigger so that they don't smoke. Bigger heatsink, bigger transformer again. It ain't easy to increase the power output of an amplifier.
| | #6 | |
| | #7 | |
Since it is already rated for a 4 ohm load, then using more powerful transistors and heatsinks or doubling them, using a more powerful transformer and increasing the trip point of the current limiters, then it will double its output power to 200W into 2 ohms. You probably cannot buy 2 ohm speakers so use two pairs of 4 ohm speakers in parallel. You still might not notice the small increase in power. An expensive way to gain nothing much.
| | #8 | |
Don't forget, bass guitar is pushing an amp HARD! - you need a good reliable design, pushing the outputs close to their limits doesn't give that!. | ||
| | #9 | |
Did you notice that its distortion is rated for only 10W?
| | #10 | |
| | #11 |
The Velleman amp is a simple circuit that uses resistors where a better circuit uses high impedance current sources. The guy who blew it up said that the LM3886 amp IC that he replaced it with sounds much better.
| | #12 |
Not meaning to bump or anything, but: - would good cooling mean 4 ohm operation is safe for the amp? - If so, I will use 100w 4 ohm bass speaker if the above is okay. Any suggestions to which model? - is there that much benefit from using larger value supply capacitors. At the moment they are 3300uF. In the manual it is suggested 4700uF for "better performance". Is it worthwhile changing them, either to 4700 or higher? Thanks for any suggestions | |
| | #13 | |||
| | #14 |
Okay, I think I will just leave it operating at 8 ohms in that case.
| | #15 |
| amplifier, bass, guitar, power, project |
