While trying to select a MOSFET for a project, I see a lot of them incorporate a schottky diode. What is the purpose of this?
| | #2 | |
http://www.irf.com/technical-info/appnotes/an-967.pdf
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | ||
How would this affect using one of these in a simple switching application a reverse polarity protection circuit?
Wouldn't you just use a diode in a reverse polarity protection circuit? Are you sure you aren't referring to the parasitic diode that's always present in a MOSFET? Or are you actually referring to a diode they integrated into the MOSFET on purpose? Your last sentence didn't seem to make too much sense though. Try writing two sentences. | |
Yeah...I was cutting and pasting and it didnt work out. A lot of the data sheets that I've seen of MOSFETs have a diode or schottky diode in the symbol . Im planning on using a mosfets as a simple 12V switch, and also as reverse polarity protection (a regular diode will drop about .7 V, but with a mosfet, there would be less. (see figure D) http://www.elecdesign.com/Files/29/9945/Figure_01.gif Sorry about the poor previous post. | |
| | #6 |
THose are the intrinsic parasitic diodes that come with every MOSFET. They don't purposely put it in. It just ends up there always. There is no real reason people "put it in". It's supposed to be a very powerful, but very slow diode. I guess for some reason they have less voltage drop than REGULAR diodes so you can use this to your advantange. I'm pretty sure if you don't look for regular diodes you will find diodes with less voltage drop than the MOSFET intrinsic diode. It's not hard to find MOSFET intrinsic diodes with much higher voltage drops than discrete diodes- just hunt around on IRF's datasheets for a while.
| | #7 | |
__________________ L.Chung | ||
| | #8 |
I've tried that and it works very well too. With other control circuitry MOSFETs make very good bridge rectifiers as well.
| | #9 |
I'm getting tired of having electrolytical caps blowing up in my face when building my guitar tube boosters vintage design. It is hard to know right away what pole I need and by then I am sitting there with fluff in my face and a hearing problem. The pedal has great sound but I don't want to sell any of them until I figure this out. Could anyone explain the figure discussed and draw a schematic that I can understand without an education. I am using 24VDC powersupply with several volts and mA to spare. I get 12VDC and 18VDC of regulated voltage to use on the tube. I could use a Schottky diode I guess. But what kind? And how to connect it? Summary: Using 12 and 18 VDC voltage regulators Electrolytical Capacitor 100uF (are running out of stock if this continues) Power Supply: 24VDC 1A Tube: need 12 and 18VDC, at least 150mA Schottky Diode: Goes where??? What kind? Will it protect circuit during wrong polarity? I attached a picture with my working configuration without polarity protection and zip file of me playing guitar with the pedal for your listening pleasure. I am a total n00b at guitar too. =) Last edited by Rewind; 6th October 2009 at 03:07 PM. | |
| | #10 | |
Be careful when using the diodes that are built into mosfets. The mosfet has to dissipate the heat for the diode as well, and you have to take this into account in your heat calcs. Never use the body diode for a protection diode. This diode is part of the mosfet structure and is "in use" while the mosfet is conducting. If it is trying to handle a reverse current when you turn the mosfet on, you can get some spectacular results ending with buying more mosfets. Last edited by smanches; 6th October 2009 at 10:53 PM. | ||
| | #11 |
Your schematic of a vacuum tube circuit makes no sense whatsoever.
| | #12 | |
It would seem to me that the extremely popular "synchronous rectification" process is operating in this mode.
__________________ de KI6RWX | ||
| | #13 | |
| | #14 |
As mosfets are used heavily in high power amplifier circuits, the diodes are in circuit to protect against eddy currents seen as speakers are seriously inductive loads. On switch off you can get high return currents that unless the diodes are there, will fry naff transistors like tip's and darlington pairs etc. Similar in motor control circuitry a diode is placed in parallel with the load to eliminate these same currents backing up into circuit when the devices switch off and the loads are still effectively generating. They merely protect semiconductive components as fuses and switchgear are just not practical or effective at the typically low levels transistors operate at. | |
| | #15 |
The point I wanted to make is the difference between the body diode, which is the intrinsic diode that is formed as part of the mosfet structure, and a true reverse protection diode which is sometimes embedded into a mosfet, or just used externally.
| diode, mosfet, puporse, schottky |
