Originally Posted by smanches The point I wanted to make is the difference between the body diode, which is the intrinsic diode that is formed as part of the mosfet structure, and a true reverse protection diode which is sometimes embedded into a mosfet, or just used externally. |
I still missed the point. How can activating a MOSFET while its body diode is in reverse recovery mode damage anything?
This diode is part of the mosfet structure and is "in use" while the mosfet is conducting. If it is trying to handle a reverse current when you turn the mosfet on, you can get some spectacular results ending with buying more mosfets.
I understand that the body diode ratings must be respected, but what is this reverse current problem? You're not referring to shoot-through on an H-Bridge due to timing problems?
