Old 28th August 2006, 08:57 PM   (permalink)
Default Are protection diodes necessary with FETs?
Is it necessary to use a protection diode when using an FET to drive a relay (as when you use a bipolar to drive a relay)???
sazerac99us is offline
Old 28th August 2006, 09:41 PM   (permalink)
Cool
Yes, if you are using the drain connection to drive the minus side of a relay coil, add the dide across the relay coil. Although MOSFETs have an intrinsic body diode, they are not connected correctly for that particuar type of protection.
Bob
Bob Scott is offline
Old 29th August 2006, 03:11 AM   (permalink)
If you mean putting a diode in parallel with the coil with reverse polarity, this is typically done to quell the flyback effect of the collapsing magnetic field, which causes a high voltage. This type of diode arrangement generally should be done regardless of the driving device.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
