| Hello, I am looking to build a circuit for my car however I cannot figure it out on my own. I can describe what I want it to do any maybe someone can give me alittle info on it. From what I remember back in highschool electronics, this shouldn’t be too difficult. Thank you for your time. Alright. I would like little blue LEDS that I place around or under the car to turn on when I shut off the engine and stay on for only 5 minutes. Ive seen it don’t before and I believe it uses a “relay” or something , yet I cannot remember how to do it. Somehow the circuit knows when the car’s accessories (I guess) are trigged off and on. I also need to know as much as possible for the job. I would like to use maybe 20 LED (few or less) and have them power off the car battery for the 5 minutes after I turn off the engine. Thank you again for any help -Paul | |
| Is it possible to just use a large bank of capacitors to keep the LEDs on? When the car is on, the capacitors will slowly charge up (and the LEDs brightness will slowly increase). When the car turns off, the capacitors (not the car battery) power the LEDs until they become empty. Your LEDs are probably much larger than what I am imagining, so a capacitor bank for 5 minutes of power is probably not practical. You could use a relay or transistor with timing circuitry like a 555 timer. I do not know anything about cars, but I suspect you can tap into the power wire that is controlled by turning the key partway (to activate the car's electrical system). Last edited by dknguyen; 21st August 2006 at 07:47 PM. | |
thnk u | ||
| i will probably have 2 of the following rods 24 INCH BLUE LED RODS w/21 LEDs LEDS BLUE - 24" CAR LIGHT ROD - Led technology w/21 individual LEDs Works with any 12 volt power source. Less then 1/2 amp draw LEDs are clear when off {2 variables - solid and chase - swichable} Transformer built in | |
| a time delay circuit should be all you need ... check out the internet and google for lots of plans ... you'll use a relay, wired to your ignition terminal (off the keyswitch) ... once the terminal is turned off (key = off), the time delay circuit is energized and begins its countdown, turning the connected leds off after the time expires.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| thank you, i'll give it a shot | |
