Old 9th August 2006, 09:04 AM   (permalink)
Default dc to ac converters
can anybody tell me how do dc- to ac converters work??? what came to mmy mind was to use oscilators but then i am am confused that how it would work.
can anybody tell me.
mshemyalnisar is offline
Old 9th August 2006, 09:17 AM   (permalink)
You are correct, they use oscillators.
Old 9th August 2006, 09:50 AM   (permalink)
They use an oscillator, transformer & transistors. Try searching for Power Inverters.
F. S. Ahmed
fsahmed is offline
Old 9th August 2006, 01:57 PM   (permalink)
Some inverters use a modified sine output, which is a step approximation. Still others use 2 oscillators, one at high frequency on the initial stage used to boost voltage, while keeping magnetics small, and a secondary 60Hz oscillator on the final stage for the output section. It all depends.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 9th August 2006, 04:30 PM   (permalink)
POST DELETED BY MODERATOR, IT WAS INSULTING AND OFFENSIVE!
HiTech is offline
Old 11th August 2006, 08:34 PM   (permalink)
Depends on what........
And secondly, the thing that is confusing me is how would the ground be establised in this case??
Old 11th August 2006, 10:01 PM   (permalink)
Why do you want a ground?, and if you do - then simply connect one of the output wires to ground.
