Old 6th August 2006, 08:28 PM   #1
Default looking for circuit that turns light on at night off during day
Can someone show me an effective circuit that will turn on at night and off during the day.
I have been playing around with one circuit I found but the problem was that the LEDs always drew some power from the batteries even when in full light (they should've been off). Then when it was dark they were never bright enough. So in order to increase the intensity of the LED I increased the source Voltage but this also increased the voltage drain when it was off (in full light) .
Justin..
mettam is offline
Old 6th August 2006, 08:54 PM   #2
There are plenty of circuits on google. Search there first, and then come back if you can not find any.
Marks256 is offline
Old 6th August 2006, 09:20 PM   #3
hey! This's my sentence!
iČ = jČ = kČ = ijk = -1
_nox_ is offline
Old 6th August 2006, 10:28 PM   #4
If you use solid-state technology there is always leakage currents. You might not be able to do anything about it unless you use a relay, but then what happens is you need an active to control the relay- which means you need a circuit that will amplify the photo-readings you get to drive the relay. What will happen is you get zero current consumption when off, but when it's on you have the to power the LED and the relay, and the relay probably consumes way more power than the LED. So the power you end up saving when off ends up being used up (and then some) to power the relay when the LED is on.
How much off power consumption did you measure?
dknguyen is offline
Old 6th August 2006, 10:49 PM   #5
I was getting a power consumption of 1.6 to .1 when the LED was supose to be off,
I hope that answers the question you where asking ?
mettam is offline
Old 6th August 2006, 10:51 PM   #6
Uhhh, what did you measure? What units?
dknguyen is offline
Old 6th August 2006, 11:00 PM   #7
Please post the schematic an explain properly what you want to do, what application does your circuit have?
if I know the answer.
Hero999 is offline
Old 7th August 2006, 12:13 AM   #8
He probably has a photodetector shorting the LED to turn it off.
audioguru is offline
Old 7th August 2006, 08:13 AM   #9
Default Problems with my circuit.
My batteries are putting out 7.24VDC
The Potentiometer is dialed to a point where I get good illumination when on (in Dark) and apears off when light hits the Photoresistor.
Question 1.
When I try to read the resitance of the pot I get 1.14 when the multimeter is set to 20K, how should this be read is it 1.14 Kohms?
Question 2.
I am taking my multimeter readings from A and B (from the pos & neg of the LED). Is this the correct place to take the reading from ?
Question 3.
The LED Load when on is 5.85V This seems a bit much for a LED that is supose to light at only 3V.
Do you agree ? if so how can I reduce my voltage to the LED and still get the illumination I want ?
Question 4.
LED Load when off is 1.3V
This is the problem because I would expect no voltage to be read when the LED is not lit, can you sugget why it is drawing so much voltage when it apears off and how I can solve this ?
looking for circuit that turns light on at night off during day-circuit_lightoffdarkon.jpg
mettam is offline
Old 7th August 2006, 11:48 AM   #10
Question 1.
Are you reading the resistance in circuit, or out?
Question 2.
I assume you mean the voltage reading?
Question 3.
Put a resistor in series with the LED. Use Ohm's law based on the current spec of the LED.
Question 4.
It seems the bjt is slightly on. I'm not sure I understand why the LED is in parallel with the collector resistor. Why not eliminate the collector resistor and put a series resistor in line with the LED based on Q3 above?
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 7th August 2006, 11:53 AM   #11
Compare this circuit, which works.
Creationists have a world of evidence
AllVol is offline
Old 7th August 2006, 12:35 PM   #12
Changing the transistor to an NPN confuses understanding the circuit.
But it looks like the original circuit would work backwards, the LED would light when there is light.
Old 7th August 2006, 03:21 PM   #13
I am reading the resistance directley from the Pots leads while it is pluged into the bread board, the battery is turned off.
Yes I mean Voltage reading.
What is the bjt ?
mettam is offline
Old 7th August 2006, 03:55 PM   #14
Reading the pot while in-circuit is not just the pot resistance, it is with the surrounding circuit, and could be way off - even different when power is applied. The bjt is short for bipolar junction transistor. Try eliminating the collector resistor and put a small series resistor with the LED.
Analog is offline
Old 7th August 2006, 06:15 PM   #15
Is that a resistor going into to Transistor ?
mettam is offline
circuit, day, light, night, turns
