| Hey guys, I live in an area that is really bad for power. The weather does not have to be severe, and the Hydro goes off quite frequently. I have seen devices (lamps, radios, etc) that are telephone line powered. Just curious on how much current can be drawn from the telephone lines? Basically I want to build a simple power supply that will allow me to run small lamps for reading, or to chargge batteries in the event of a power interruption/failure. Any LINKS, schematics, information that I can download? Thanks | |
| You can draw very little current off the phone line, and you are likely to get in trouble attempting it! - modern exchanges will detect the fault, and presumably arrange to send an engineer out?. | |
| You looking at 20mA @ 6 to 9 V and as Nigel said causing a fault condition on your line, your lines not faulty but if you don't dial to a valid number most modern exchanges think its a fault. Or 1-2mA at 48V this is trickle charging from the line, again to much and the exchange thinks you have a fault. Not a big power source even for battery charging, how long to charge a 1000mA/H battery? | |
| For sheer convenience it is really hard to beat a deep cycle marine battery and a 400W Inverter from Powerbrite. | |
| Drawing current from a telephone line causes it to appear to be "off hook" to the telephone central. Your telephone line would be busy to the system.
