Old 21st July 2006, 07:10 PM   (permalink)
Question Source for Power Mosfet 2SK1058/2SJ162 or substitute?????
Anyone got a good source for these that won't cost $10/ea??? That seems so high for a basic power mosfet.
Also, if there is a good sub for these, I would appreciate any leads. These will be used in an audio power amplifier stage as a complimentary output pair (N-chan/P-chan). I'm in the USA.
Thanks!
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 21st July 2006, 09:22 PM   (permalink)
Thanks!
These guys have em for under $9 (not much better)
http://www.ampslab.com/components_powermos.htm
What specs are you looking for other than volt/amps & package rating?
TO-247 & TO-220 packages are much more common than a TO3P which partially explains the higher cost. Can you use one of the more common packages with adequate heat-sinking? You'll really have to divulge important specs before someone can faithfully suggest a lower cost alternative.
Optikon is offline
Old 21st July 2006, 09:41 PM   (permalink)
The FQA7N80C should substitute for the 2SK1058 and the FQA9P25 should substitute for the 2SJ162. Both are available from Mouser. cost under $3 each.
Russlk is offline
Old 21st July 2006, 11:04 PM   (permalink)
Thanks for the replies. The package is not important to me. The voltage and current ratings need to be compatible. Also, I believe these are lateral MOSFETs, and characteristics commensurate with these devices is also a point.
Analog is offline
