| ok i want to connect a LED light (or more than 1) to a switch for my car. Can some one please help me? Thanks! PS~ im a no0b at this electronic stuff so please go easy on me! | |
| is any one going to help me?! | |
| ok ok! you just waited 50 minutes. do you think that there is someone 24/7 to help you here? ok. you could do this: conect a led in series with a 1K resistor and connect it to the power suply. if you want more leds just connect a resistor for each. i will not post the calculations. if you search the forum i am sure you will find them a few dozen times. just look around........ | |
| can u please do a diagram? i dont know what to connect to the switch. and how is the LED going to connect to the fuse box? | |
| ok, here is a place where it explanis how to calculate the value.... http://www.electro-tech-online.com/viewtopic.php?t=2307 just do a search and you will find them....... | |
| Okay, well you got your power supply already (the battery) Now all you have to do is determine what kind of LED you want in it, if you want chasers (Knight rider lights) it'll be a bit more difficult, then you have to figure out how much power your car's battery puts out. Then once you know what the voltage is of the battery, and you have an LED picked out, you have to get your resistor for the LED(s) You figure this out by finding out the voltage the LED can handle to get maximum illumination, what the draw of the LED is is (in miliamps, usually between 5 and 25), and what the voltage of the batter is, and calculate this equation. R= (Vs-Vl)/I R = Resistor Value in KiloOhms Vs = supply voltage (Your Battery Voltage) Vl = LED voltage (The Max Voltage of Your LED) I = LED current (Miliamps) EXAMPLE: So say your car is running a 12v car battery (average) and your maximum load of the LED is 4v, and it has a 20 mA draw, then your resistor value would be .4KO, or 400 Ohms. After that you need a switch, and you need to find available space on your dash. Wire up your circuit, and use your battery in place of the schematic battery. Now in your circuit before you place the resistor, and LED, run the positive (and possibly the negative depending on what type of switch you choose) to a hole drilled in the dash. Then place the LED wherever you want it, making sure your resistor comes BEFORE the LED. If you plan on making a chaser LED, then I'll get you a link, unfortunately it's a 9v, so if you do have a 12v battery, which is normal, you'll need to get a 12v to 9v transformer or something similar. http://www.aaroncake.net/circuits/chaser.htm Got the idea ?
__________________ E=MC^18357891237358179238, it\'ll still come out right every time. Try it some time, it\'s all relative to the equation. | |
| but im not connecting the LED to the battery.....i want to connect it to the fuse box | |
| So you'd rather run it off a 110+ Volt Alternator, don't think that's a good idea at all.
| so i have to connect it all the way to the battery? | |
| It's a better idea, and much cheaper, in order to run it from the fuse box it'll probably cost you 10x more to get a 110->9v or so Transformer, and you'd have to run a line back to the alternator anyway, which is just by the battery, so spending $.10 more on a bit of wire is better than shelling off $5-20 for a transformer.
| Nostrafus, I don't think elecwanabe means that they wants to run it to the alternator. I think they're talking about the 12V fuses, usually situated near the dashboard. | |
| phasor's right......im talking about the fuse box on the dash. can someone please do a diagram of this? connecting the switch to the LED? i am a visual person......thanks for all these replies though! | |
| Nosatrafus, well, i understand that he wants to connect it to the fuse box from the car.....cause that's what he is talking about....is he? and about the one that runs from 9V well....i think that it cn run from 12V too, or he coud use a LM317 reg... as you thought about it.....with a transformer? /an even simple solution for the chaser will be to connect it trough 5 diodes, wich will be less expensive then the LM317.....but still.......he just wants a led so....... | |
| Here it is, to put you out of your misery :lol: You can add more LEDs, either in series or parallel with the existing one, but you will need to adjust the value of the resistor. | |
| THANK U PHASOR!!!! Sweet Jesus.....that's all i needed to c lol. all i need to do now is find out what kind of resistor i need. do i use that same equation that u guyz gave me? | |
