+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 33
Thread: Circuit Problem!!!
  1. #1
    semajholland Newbie
    Join Date
    Jul 2006
    Posts
    3
    Default Circuit Problem!!!
    http://www.freeinfosociety.com/elect...ew.php?id=1662
    Can anyone tell me the matter with the circuit in the link above. I need it for a project that needs to be finished in 10 days and i'm starting to get desperate. Also there is an un-named transistor by the 555. Anyone suggest a suitable value????? Please help, thanks.
  2. #2
    HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,506
    The 555 is a timer IC chip not a transistor. However the transistor whose collector is tied to pin 2 of the chip isn't identified in that diagram.
  3. #3
    OutToLunch Good OutToLunch Good OutToLunch Good
    Join Date
    Jun 2006
    Location
    North Carolina, USA
    Posts
    355
    The unlabeled transistor is just a simple NPN - low current and the CE voltage will be low as well. The sole purpose of the transistor is hold pins 2 and 6 at a certain level to disable triggering in the 555. Use a 2N2222 or a 2N3904, etc.
    As far as the circuit not working properly, I would suggest going through and debugging in steps. First make sure that the circuit is built properly - take your time and be anal. Have copies of datasheets at hand so you can look at pinouts, etc.
    If it is still not operational after making sure it is wired properly, then start at the 555 timer and see if that is doing what is should be when eneabled (the output (pin 3) should be approx 1 sec pulses).
  4. #4
    oldtimer Newbie
    Join Date
    Jul 2006
    Location
    Florida (english ex pat)
    Posts
    94
    The 555 is an astable which pulses at a 1 second rate, the pulses are fed into the 4518 counter and when pin 7 goes low the relay is energised. The 4011 is a quad 2 input nand gate and is used to forwrd bias each diode or combination to display the pulse count..Any general purpose transistor will do in the 555 circuit.
  5. #5
    oldtimer Newbie
    Join Date
    Jul 2006
    Location
    Posts
    94
    You didn't say what wasn't working,does the display work? does the relay energise? check pin 7 on the counter does it go low,are there pulses on the counter clock pin.
  6. #6
    oldtimer Newbie
    Join Date
    Jul 2006
    Location
    Posts
    94
    Hitech,
    I think you ought to take that silly comment out, it makes you out a moron.
  7. #7
    eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    The 555 timer is connected for astable operation. The 4510 is a BCD counter and the 4511 is a BCD to 7-segment decoder. After the 9th pulse the carry (pin 7 of the 4510) should switch the relay off. Try with one transistor that drives tha relay, with a base resistor. What's the problem exactly?
    The unnamed transistor can be a bc547.
  8. #8
    semajholland Newbie
    Join Date
    Jul 2006
    Posts
    3
    I know a 555 IC isn't a transistor, i meant the transistor by the 555 chip. (Learn to read HiTech!!!!!) It's un-named. I wanted to know if i could put any old npn in it's place.
    The display isn't lighting up and when i connect 12v across the circuit the relay automatically turns on straight away and doesn't do anything.
    The output of the 555 is held high by the switch when it's off. But flick the switch and the out put goes low but stays low. No pulsing. I noticed the discharge wasn't connected into the circuit is this essential for correct operation.
    All i want is a circuit that either counts down from 9 via a 7 segment display or by LED's turning off. Anyone have any circuit diagrams????
    Great help, Thanks.
  9. #9
    Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent
    Join Date
    Mar 2006
    Location
    Michigan, USA (GMT-5)
    Posts
    2,892
    Quote Originally Posted by oldtimer
    Hitech,
    People are free to express themselves in any way they see fit. I think your comment makes you out a fascist, and a destroyer of our cherished liberties.
  10. #10
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    It sounds to me like your switch may be normally closed instead of normally open. Can you check it with a multimeter? You could also try holding the switch closed (open?) and see if it runs.
    Ron
  11. #11
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Quote Originally Posted by semajholland
    No, this is a minimum component astable multivibrator. It's ok.
    Try to connect pin 4 of the 555 to 12 V. Don't connect the relay and check the output of the timer.
    This can be easily done with a microcontroller, can you use it?
    EDIT: pin 7 of the 4510 is inverted?
  12. #12
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,506
    Thumbs up
    Quote Originally Posted by Papabravo
    Thank you! It's amazing how many peeps there are on this globe who desire to squelch others. The right to free expression exists in America, but still has it boundaries as set by laws. Within Internet forums, for the most part, self-expression is bounded by the rules set forth by the administrator(s) or parent organization.
    What some folks have failed to realize about my choice of sig lines is my sarcasm (however funny or not). My current sig line is non-threatening (in reality) and I don't plan to edit nor change it just because another member feels put out by it!
    Now, having said all that, may I suggest that we keep this thread on topic?
  13. #13
    semajholland Newbie
    Join Date
    Jul 2006
    Posts
    3
    I think the problem could be the I.C's. Because i couldn't get hold of a CD4510and a CD4511. I had to substitute them for a BEF4516G and BEF4511B. I don't think these are doing their jobs the same. Does anyone know where i can get hold of these I.C's??
    When i test the output of the timer, sometimes it pulses at 1 second intervals and sometimes it doesn't. Loose connection?
    Can anyone come up with a circuit that counts down with L.E.D's instead of a 7 segment display?
    Thanks.
  14. #14
    Hayato Excellent Hayato Excellent Hayato Excellent Hayato Excellent Hayato Excellent
    Join Date
    Jun 2006
    Location
    Brasilia, Brazil
    Posts
    657
    Blog Entries
    1
    Thanks.
    Once upon a time, in a cars message board:
    Well, I have a Mustang, nothing works there!
    ...After some time, after all the replies...
    Well, I forgot to say that I could not afford a Mustang and I had to buy a Galaxie!
    Well, from CD4511 to BEF4511B there is no difference.
    But from CD4510 to 4516 there is a BIG difference, the 4510 is BCD, the 4516 is binary. So it will not drive your 7 segment display, unless you add a binary->BCD converter there.
    The relay is not working, is it? Try to remove the 2N3053 (NPN, the one that is connected to the relay coil), the transistor pair there is not needed.
  15. #15
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by Hayato
    Yeah, but for a single digit, BCD and binary are the same. The counter is being jammed to 9 when the switch is depressed, so either counter should work fine.
    The 2N3053 is useful if you are driving a high-current relay coil (>100mA). Otherwise, as you say, you can remove it and ground the collector of the PNP.
    Ron
+ Reply to Thread
Page 1 of 3
1 2 3 Last
Tags for this Thread
