| hey I made this PICAXE-08M a while back and there is something wrong with it... could anyone please see to the attached images and help thanks.
__________________ <( \"<)....kirby!!!....0==[=====> | |
| How can people be expected to offer advise on a programmable chip, when we don't know if it's programmed correctly, or even what it's supposed to do, and you don't even mention what's wrong with it?. | |
| no no no no, dude it isnt programmed, theres something wrong with the way the parts are soldered, like wrong legs or wrong resistor values
| | (permalink) | ||
| lol hmmm... your being very difficult i know it wont do anything, but at the moment it dosent even work what do u mean why? obviously i dont know what the problem is for sure, thats why i hoped an expert could see by looking at it.
| Nigel, Is this another one of those secret comedy writers you have on retainer? | |
| spare me your inside jokes
If you buy a blank video tape, and put it in your VCR, do you expect to get a film from it? - NO - because it's blank, so why do you expect your blank PIC to do something?. | ||
| omg.....no voltage runs through it even, do u see what i mean now gosh its like a duet.
Then why not use your DMM and trace the supply around the circuit board to see where it stops? JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| ok thanks JimB. umm..although i just got a pm about the resistors. apparently they are the right resistors but round the wrong way or in the wrong order or something.....he didint specify. is there a way u can see if they are wrong by looking at the pictures?
| We may have found mstechca mk2 Might give us a clue to what it's supposed to do? Maybe sitting and doing nothing is how it's supposed to work. You could keep applying voltage till the magic smoke comes out. Did you know all electronics works on magic smoke? If you release it, it will stop working. Quote:
PS those red & black wires have to be between 2.5v & 5v else poof goes the PIC (hope it's not a 9v clip at the end)
__________________ Bill Home of the Firefly PIC Tutor Inchworm ICD2 http://www.blueroomelectronics.com Last edited by William At MyBlueRoom; 1st July 2006 at 06:54 AM. | ||
| Ya know...a schematic is much more useful than photos of the circuit...easier to analyze. What do you expect it to do anyways if you haven't programmed it for anything? Do you have a voltage regulator? How exactly are you trying to get 5V to the PIC? What do you mean no voltage is running through it? The voltage measured across the +V and GND pin of the PIC is a floating voltage (constantly changing)? THat would mean there is a break between the traces going from the battery to the PIC. It's really hard to tell what you mean when you give so little detail and osbscure photos. No one is going to sit down and draw out the schematic themselves from your photos. Last edited by dknguyen; 1st July 2006 at 07:05 AM. | |
| http://www.rev-ed.co.uk/docs/axe090.pdf contains the circuit, this board is the PIC programmer and it only shows 2 resistors, 10K from serial in to ground and 22K to PIC pin2(ser in).. There is nothing to check, although I don't like using the sleeve of a 3 pin plug for data, that's where the shield (gnd) should be. | |
