hey,
I was wondering if the L293D H-Bridge is effective in running a small DC motor for a model representation of a door. If not, have you found a another H-Bridge that could do this job effectively and simply. because apparently the L293D is capable of running a stepper motor ! thanks,
<( \"<)....kirby!!!....0==[=====> |
no one knows about H-Bridges?........
I don't know much about h-bridges but there are many posts on this forum about h-bridges and from what i can gather the h-bridge can run a dc motor forwards and backwards and i can see no reason why it should not work for your task. The L293D is very commonly used for driving stepper motors and dc motors.
i suppose it depends upon the specifications of your motor, DC operating voltage? current draw? i'm no expert on h-bridges. hope this helps don't forget a reverse biased diode across the windings to prevent counter electro motive force. |
ok thanks JR i'll chek that out
try L298 .. it's out 4A and can frive 2 dc motors ..
bye |
rancid, you need to tell us what current your motor will pull. if it's a small motor, I'd bet the current level will be fairly small and thus the L293D will work just fine. You will only need 1/2 of it, by the way.
I built a servo to drive a small antenna using LM324 op amp, so power is not necessarily needed.
see my website: www.geocities.com/russlk |
well my motor is also very small (hence the model representation).
i preferably wanted the most simple H-Bridge possible thanks, it only needs to move a very small and light piece of wood that will be on wheels or a rack.
Does the motor need to go both ways??
If so then just use the L293D. If not a couple of transistors will do it. |
yes well when u open a door, u would like it to close....
so yeh both ways is essential thanks for the quik replies and the L293D is too much power, it can control a stepper motor
What are you using for a controller? a PIC micro can output 20 mA which is enuf to drive a small toy motor.
