Hi, I need some comment for these circuit, their pros and cons. Which one is better? which one drives faster and etc.. thanks | |
Basically transistors allow you to add PWM speed control, relays don't. If you don't want speed control?, go with the relays - it's far simpler!. You can also do a hybrid version, a single transistor for PWM speed control, and a single DPDT relay for forward/reverse. | |
Oic.. i think the relay is more suitable for me. Is the speed controlled by 555 timer? How does it work?
| | #4 | |
| | #5 | |
| | #6 | |
| | #7 |
The relay cannot be used to control the speed just because it switches not fast enough? how if, the motor is drive too fast, i want to slow it down, by using a 555, the output of the 555 is connected to the Vcc of the H-bridge. Can this work? Thanks | |
| | #8 |
Yes, but NOT fed from a 555, you would need a high power transistor or FET to drive Vcc - and it's then fairly pointless using so many relays, a single DPDT one would do.
| | #9 | |
| | #10 | |
| | #11 |
oh.. then the base to the microcontroller, then the speed is controlled by it. right?
| | #12 | |
| | #13 |
| I am in really trouble can any one help me how to connect 555 timer to the H Bridge to control speed ??????? | |
| bjt, hbridge, relays |
