Old 16th June 2006, 09:19 PM   #1
Question Need help for decoder output Toggling
Iam using Holtek Encoder and decoder for RF control of an equipment. I just want to ON and OFF the equipement with a single push button. If pressed once it should turn ON the device and in the next press it should turn OFF....
Here in the decoder , there is a Latch inbuilt. Because of this , if i set a perticular address and a data bit of 0010. it comes in the decoder and turning ON the device and the same data will be there in the latch till the next data comes. When i press the button again, the same address and data will be transmitted , so the device is not turning OFF....
I need to use only one button control for toggling the device... Can any one please suggest an idea to solve this problem plssss....
Dr.Edison
RK NAIR is offline
decoder, output, toggling
