| Just to say hello to all ive just, practically justv registered. | |
| Hi all, there is practically no other way than connecting just three inputs of a 4017 somewhere. They are all important for proper function of the chip. The input pins (in sequence) are: pin13 (ClOCK INHIBIT), 0=ENABLE CLOCK, 1=DISABLE CLOCK; pin14 (CLOCK), self explanatory, a counter without a clock signal can't count; pin15 (RESET), 0=RUN, 1=RESET. According to the describtion of the malfunction I analyse reverse polarity for the power supply, in other words "CD4017 - RIP" Basic rule in electronics: Before applying power to a new circuit check the power without ICs. Can also be done on a breedboard using IC-sockets. Power down until all voltages on the board have deminished. Insert the ICs and run. (saves some money too) Boncuk Last edited by Boncuk; 24th July 2008 at 01:24 AM. | |
For example, National Semiconductor application note AN-375 for HCMOS parts stipulates 10nF per every two to five packages spaced within 12cm, 100nf for every ten. That would be in addition to local board decoupling of, say, 50-100uF of aluminum electrolytic, or 10-20uf tantalum.
__________________ Corey Rapp's Law of Inanimate Reproduction: "If you take something apart and put it back together enough times, you'll eventually have two of them." | ||
| Modify my circuit, replacing the optos with relays. | |
