| I am now trying to design constant temperatuer current souce about 2A, 12V to drive 40 LIGHT Emiting diode, To drive LED light contstatnly, there's lots of problem, I found, such as consumption current variation following temperature variation etc..., Could anybody give me a swolution for this? | |
| Now, I intend to make a constant current supplier to control constant luminosity of LED. if current was decreased by temperature variation or other reason, the luminosity of LED is decreasd. so I need constant current source independent to temperature variation. | |
| i think you don't have such a great variation of temperature so that the leds loose the intensity. could you use a LM317 voltage regulator? it soulds limke the simplest solution for me. and about modifying there brightness, you could use a PWM, wich will have a better efficency. | |
| j2bichon has not mentioned whether efficiency is an issue, so assuming it is not, then this circuit should work adequately. Vin should be at least 3V higher than the highest output voltage required. | |
| Phasor, I think your circuit would give problems. LEDs should never be driven in parallel without limiting resistors. The voltage/current relationship between indvidual LEDs when lit will differ, so that at a given voltage their relative brightnesses will be different. Indeed, some may not light at all. If I read the data sheet for the LM350 correctly, there is 1.2v between output and the control pin when it is working correctly. That means the current through the 0.6ohm resistor (and the LEDs) will be 2A. I think some of the LEDs may pop! | |
| When I drew the LEDs, I just meant to draw a general load - I didn't intend hooking them up specifically that way :wink: | |
| Hi, ive used leds in parallel many times with a common resistor, i know that they may differ individually, and i always look out for it, but i have had no trouble like that, even with different size leds. I have used seven segment displays with a common resistor, and yes, there has been a slight difference in brightness from the one (two segments) to the eight (all seven), but not enough to worry me. John | |
| 8) I need 10V, 2A to control cross connected paralleled LED strings(10 x 4), I will use this for automotive filed to control Turn and stop signal and by using this constant currrent source, i should detect how many LED are fail. | |
So what have I missed? | ||
| My Led consum Max 150mA, normaly 100mA and if I use constant vltage source, the currunt consumtion is changed denpend on LED series resistor. | |
| Hi all, i am new here and I would like to require some help. Could anyone tell me how to design a simple constant LED brightness but have variable input voltage (DC voltage range of 0 to 60 Volts). My problem is that whenever I varies the input voltage, my LED light brightness varies with the voltage. But I do not want this. I would like it to be constant all the time. The LED purpose is just to indicate the power is on. Thanks, :? ckw | |
